Cobalt Extruded Honed Manifold
Old Nov 24, 2007 | 06:38 PM
fr33ride_101's Avatar
Hi. has anyone installed a Cobalt Extruded Honed Manifold from Gmpp ?
i was gonna order it for my 2.4L , is it worth it? any hp gains?
thanks!
Old Nov 24, 2007 | 06:41 PM
GULLABLE0NE's Avatar
not worth it unless your trying to stick w/ chevy parts. i never dyno'd my car but at most i would say 5-8 hp gain
Old Nov 24, 2007 | 07:20 PM
well thats the thing, i would like to stick with gmpp for the warranty.
i was thinking of getting that and the gmp cat-back and gmp intake.
Old Nov 25, 2007 | 12:16 AM
gocanucksgo's Avatar
I have all 3 of those and they're great...never had a CEL or any type of problem with any of it. I'd highly recommend all 3.
Old Nov 26, 2007 | 04:26 PM
anyone else?
Old Nov 26, 2007 | 04:29 PM
D4u2s0t's Avatar
it's more expensive and gives less gains than any other header out there. totally not worth it imo. a header doesn't void the warrenty anyways
Old Nov 26, 2007 | 09:03 PM
it may not void the warranty if it did not cause it! like the guy at the dealer told me "In the case of warranty the installation of aftermarket performance parts it only affects the parts involved or parts that may be affected by the install of these parts. example; if you install down pipe and header and you get a service engine soon code and the light comes on in the dash(not covered) and you keep driving and it causes damage because of it (not covered)
but if you put a performance exhaust and the left rear wheel bearing fails that would be covered. as far as performance parts from GM all parts and warranties stay covered."
Old Nov 26, 2007 | 09:08 PM
Frankruffolo257's Avatar
my buddy has it on his lsj and it actually sounds better, there is a how to on it, its on Gamebay11s car
https://www.cobaltss.net/forums/how-guide-43/how-gm-performance-parts-extrude-honed-exhaust-manifold-install-70397/
an0malous's Avatar
theres actually only 1 header I know of thats cheaper than the GMPP.
most are more expensive.
but i do agree most headers on the market will give more gains than the gmpp.
but thats on the 2.0
i think the gm manifold would probably do pretty well on a 2.4 or 2.2
Old Nov 27, 2007 | 02:30 AM
REDFOCZ's Avatar
The 2.4 has the same manifold as the SS/SC the cobalt addication header is still the best bang for buck out there.
Old Nov 27, 2007 | 03:54 AM
do you have any proof of that?...have all the headers and the manifold been tested against each other? Not being a dick, but unless they've all been tested against each other on the same model car then how do you know?
Old Nov 27, 2007 | 09:52 AM
BULLETSSMOKE's Avatar
Ok here's the deal about warranty crap. I've been dealing with it for a month now and have found the solution. No matter what header you get it will not throw a check engine light so your fine. Once you get into downpipes and high flow cats you will start seeing them. The ZZP header is cheap and CA is cheap but I heard it leaks and cracks (poor quality etc.) And another thing, if you so happen to get a aftermarket non-GM header/downpipe/cat and it DOES give a CEL then you are safe still if you get tuned. You can have the light taken off (GM can still see the codes with their device) or you can get it tuned to wear it runs a little bit richer because with the new parts your car will run lean, so just go to autozone and get a couple codes from your car read for free and go to a tuner and he will know what to do so your car's A/F ratio will be fit for no CEL. If there is no CEL they cannot void any warranty and if there is no damage then there is no problem.
Old Nov 27, 2007 | 02:24 PM
baltracer173's Avatar
I've got all 3 parts also and I love them. Dont have to worry bout any waranty issues. My dealer will fix anything on the car under warranty cause all my parts are GM. Its the way to go
Old Nov 27, 2007 | 09:13 PM
baltracer173 _---> did you have to bring it to the dealer to instal? or you can do it your self? In order to keep the warranty good and have no issuses?
Old Nov 28, 2007 | 03:42 AM
you can install it yourself or have someone do it...doesn't matter. If you're this worried, maybe modding the car isn't for you.
Old Nov 28, 2007 | 08:58 AM
On top of that, most people can't just put on a few parts and call it a day, a lot of us tend to get obsessed and continue to mod our cars even with money problems etc. It's a curse but cars are awesome.
Old Nov 28, 2007 | 04:04 PM
Oh dont worry, i am modding my car one way or another. I am just curious, its my first time putting Mods on a new car thats why! Better to be safe than sorry i guess. Thanks for all the help guys.
GaryGibblez
Jan 14, 2020 10:35 AM
Spanky's Monkey
Mar 7, 2016 06:06 PM
royce777
Sep 28, 2015 07:11 AM
Josh@ottp
Sep 17, 2015 12:03 PM
TurboWood
Sep 7, 2015 11:08 AM
