couple quick questions
Old Jun 4, 2010 | 06:05 PM
4doorcobaltowner's Avatar
#60 injectors....do they plug right into the factory injector harness? Also does the zzp triple pillar pods from a coupe fit into a sedan? Last thing, is it ok to run just one aftermarket heat exchanger (ottp new version i own) and not put the factory one in? Thanks, Tom.
Old Jun 4, 2010 | 06:14 PM
Mindrot's Avatar
Coupe Pillars do not fit into the Sedans since they are too long. I believe your only option is their 2 Pod Sedan Pillar that ZZP sells.
Old Jun 4, 2010 | 06:23 PM
Black SS/SC 06's Avatar
No, you need to upgrade the harness. I am only running the OTTP heat exchanger. It's really preference though.
Old Jun 4, 2010 | 06:29 PM
mmcgee123's Avatar
The 60's from zzp plug right into the fuel rail and harness
Old Jun 4, 2010 | 06:36 PM
Thanks, someone that's selling a coupe one and said it would fit lol (shiesty).
Also I just wanted to make sure that i don't have to buy the factory heat exchanger the ss/sc come's with. I just figured a aftermarket one would keep it cool. I plan on running a 2.9 and single pass. Any need for option b or no? Better or easier to bleed system? Thanks guys.
What if the #60 injectors came with the hahn kit?
Last edited by 4doorcobaltowner; Jun 4, 2010 at 06:36 PM. Reason: Automerged Doublepost
Old Jun 4, 2010 | 06:42 PM
Pedobear's Avatar
get a cobra heat exchanger works amazing for its size
Old Jun 4, 2010 | 06:55 PM
glen229's Avatar
when i was s/c'd i only ran a front mount heat exchanger tom, Feel free to call me if you have any questions
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
brandon04
Oct 21, 2015 07:04 AM
dennis69
Oct 20, 2015 07:39 AM
patooyee
Oct 15, 2015 05:11 PM
