Crank Sensor help
Old May 3, 2007 | 01:42 PM
RDKDESIGNSG5's Avatar
Crank Sensor help
Does anyone know how many teeth are on the crank sensor for the 2.4 ecotec?
Ryan
Old May 3, 2007 | 01:59 PM
Witt's Avatar
I'm pretty sure it uses a 58x ignition system since other vehicles with the same PCM do. All I know is that it makes 58 pulses to the PCM per crank revolution.
Old May 3, 2007 | 06:08 PM
celicacobalt's Avatar
cool, the more we can learn about the 2.4 the better we can tune it.
Old May 4, 2007 | 02:40 PM
Witt's Avatar
Ok, it has 58 teeth, on 60 tooth spacing with 2 missing teeth. Heres a little better description:
The crankshaft position (CKP) sensor circuits consist of an engine control module (ECM) supplied 5-volt reference circuit, low reference circuit, and an output signal circuit. The CKP sensor is an internally magnetic biased digital output integrated circuit sensing device. The sensor detects magnetic flux changes of the teeth and slots of a 58-tooth reluctor wheel on the crankshaft. Each tooth on the reluctor wheel is spaced at 60-tooth spacing, with 2 missing teeth for the reference gap. The CKP sensor produces an ON/OFF DC voltage of varying frequency, with 58 output pulses per crankshaft revolution. The frequency of the CKP sensor output depends on the velocity of the crankshaft. The CKP sensor sends a digital signal, which represents an image of the crankshaft reluctor wheel, to the ECM as each tooth on the wheel rotates past the CKP sensor. The ECM uses each CKP signal pulse to determine crankshaft speed and decodes the crankshaft reluctor wheel reference gap to identify crankshaft position. This information is then used to determine the optimum ignition and injection points of the engine. The ECM also uses CKP sensor output information to determine the camshaft relative position to the crankshaft, to control camshaft phasing, and to detect cylinder misfire.
Old May 4, 2007 | 02:46 PM
h0l0caust's Avatar
had mine remplace 3 weeks ago
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Stuff
Oct 1, 2015 05:47 PM
cw383
Sep 30, 2015 12:41 AM
jmelton327
Sep 26, 2015 10:04 PM
