Deuce's Progress Thread
Really?
You can run that line to a catch can or just plug it. You are aware that there are multiple other plugs on the front of your block, right? Is it really that big of a deal? It took us ten minutes w/ a shop vac and two people to tap that for a barb fitting...
All you need is a shop vac, a tap piece and a little focus. You thread the tap piece in the whole like your screwing in a bolt and as you screw it in, it will tap and push metal shavings out. The shop vac will help ensure that they don't go into the block. Before you do it, go buy a 3/8 hose barb and as you tap, just periodically check to see if it will screw in. Eventually it'll screw in a little, then you just slowly tap a little more and test each time until you can screw it in tightly...
#39
lol u have an lsj. im not throwing 4xx whp at my motor fk that. i want it to last me till mid summer next yr at the latest till this build is done. then we can go all out.
#41
cuz i know lsjs can push it more than i can and not have to worry about it. but ill run pre-build. i know we have the 2 fastest deltas in the club so might as well have some fun.
once i get the 2 bar and the meth in im game.
#47
