Downpipe For an Auto
Old Aug 7, 2010 | 01:58 PM
kissrocker52's Avatar
As the title says i am looking to get a downpipe for my 2.4 auto and really have no clue where to look so here it goes what downpipes are you 2.4s running because i know the manual wont fit our car thanks
Old Aug 7, 2010 | 03:49 PM
diablo9287's Avatar
zzp i know has the option for an auto downpipe, that about it though i think. the only thing with zzp is that ive heard quite a bit that the flex pipe on it breaks, however they do recommend better motor mounts so that doesnt happen.
Old Aug 7, 2010 | 03:52 PM
xander40's Avatar
i have the ZZP midlength header/dp combo and it works fine
Old Aug 7, 2010 | 08:20 PM
thanks for the info guys
Old Aug 7, 2010 | 10:28 PM
CordiaDOHC's Avatar
yeah go zzp. had one of their downpipes and liked it. (though it was for a manual and rubbed) so got to get a new one for an auto.
Old Aug 8, 2010 | 09:18 PM
Drew.4L's Avatar
what about muffler? im nto soo good with cars, im assuming the DP goes to the muffler? what one had a really deep smooth tone?
Old Aug 8, 2010 | 09:52 PM
b00sted06ss's Avatar
I know zap has one as an option, and I believe I've seen clear image has one for the 2.4 as well
Old Aug 8, 2010 | 10:35 PM
Mindrot's Avatar
Vibrant Header/DP is great for the 2.4 if you plan on boosting in the future. I do feel that with my set up that the primaries are a tad too large for an NA motor. But, with it being tuned I do have aggressive top end power. It's a lot of fun playing with these cars. Especially when an automatic LE5 can keep up with a stock LSJ.
PLEASE NOTE: The Vibrant set up RUBS on the Automatic UNLESS you have a solid upper mount!!!!
Old Aug 9, 2010 | 09:44 AM
RickyBobby's Avatar
I've been thinking on getting the downpipe aswell. Wishing i had a boosted 2.4L
Old Aug 13, 2010 | 12:11 AM
bumbleninja's Avatar
I have been in the market for a DP / Header combo as well. Not to great with cars as well, but I never knew there was a difference between the mauntal and auto DPs
Old Aug 14, 2010 | 03:11 PM
where is a good place to get the motor mount as well
Old Aug 14, 2010 | 04:50 PM
Drew.4L's Avatar
i think cus he manual puts out more than the auto.... then again im a novice...
Old Aug 14, 2010 | 05:02 PM
CordiaDOHC's Avatar
Incorrect.
its simply due to the fact the auto cars have the engine clocked forward towards the radiator and core support due to the transmission mounting. The cars make the same amount of power. though the autos are a bit less efficent. But the clocking makes the autos downpipes slightly longer with a slightly different angle.
Old Aug 14, 2010 | 05:09 PM
Originally Posted by CordiaDOHC
Incorrect.
its simply due to the fact the auto cars have the engine clocked forward towards the radiator and core support due to the transmission mounting. The cars make the same amount of power. though the autos are a bit less efficent. BUt the clocking makes the autos downpieps slightly longer with a slightly different angle.
thank you, so when I go to look for one, I need to find a longer one or see if they have one made for an auto tranny.
Old Aug 14, 2010 | 05:15 PM
CordiaDOHC's Avatar
Ive read that some of the manual style pipes will fit anyway. When I had my zzp 3 inch downpipe on the flex pipe rubbed on the swaybar. Now the actual length did cause the catback to be pulled inwards more. (my exhaust tip was almost behind the rear bumper).
Now without the rubbing i probably wouldnt of cared as it didnt really look like it wasnt meant to be that way (the length difference isnt much).
ZZP I know for a fact has auto and manual downpipes and theyve honestly treated me very well.
Old Aug 14, 2010 | 05:24 PM
i have looked on the ZZP site a few times, but I haven't had a chance to contact them...as of late. I will have to shoot them and email n see what they can do for me.
Old Aug 14, 2010 | 05:27 PM
CordiaDOHC's Avatar
Go select the downpipe you want. Theres drop down bars and one of those is for the auto or manual.
Old Aug 14, 2010 | 05:46 PM
Sweet! I didn't know they did that
Old Aug 15, 2010 | 05:41 PM
SS Flash's Avatar
I'm boosted but mines a CTI downpipe from Ottp
Old Aug 15, 2010 | 10:41 PM
Drew.4L's Avatar
Incorrect.
and this is why im a novice. i would never have guessed. also, this is why im on the forums, to learn about this so i know what kind of exhaust combo to get, super deep, not raspy, similar to the GMPP touring, but not so much money
Old Aug 15, 2010 | 10:49 PM
Pedobear's Avatar
with how the engine sits it kinda pulls the downpipe and back foward i simply between the downpipe and catback i had a local fab shop make something for me, basically same shape and size of the gasket just much thicker that would "push" the catback back in normal position. used some copper tube sealant to prevent leaks works.. i used a ZZP 2.5 DP w/magnaflow cat i bought off here for much cheaper. this allowed me to buy a manuals DP instead of an auto...too much work maybe but it works...
Old Aug 22, 2010 | 11:39 AM
EUGENIO's Avatar
like to know
i was thinking how would a auto run with out a cat,i was thinking of takeing my down pipe and catback off and just doing a 3inch pipeing all the way back.
Old Aug 25, 2010 | 02:39 PM
hmmmmmm i think it would run the same, but you would have to figure out a way to fix PCM from effing up..maybe a defouler?
Old Aug 25, 2010 | 11:20 PM
CordiaDOHC's Avatar
3 inch is too big for a 2.4 na auto... especially with no cat. Would kill off a good bit of lowend tq. And honestly it would be loud and raspy. 2.5" is more than enough and honestly running no cat just isnt worth the 2-3hp you MIGHT gain. Just run a 2.5" catted downpipe with a 2.5" catback.
Old Aug 26, 2010 | 12:52 PM
Zooomer's Avatar
Supporting Vendor
http://www.zzperformance.com/cobalt_...1198&catid=155
Our auto downpipes are 1.5" longer. The manual ones work in an auto but you have to pulle and contort the catback.
Our flex issue was years ago and only on one run. We have a 2 year warranty on that portion of the pipes.
Go with the 2.5", a 3" will lose all your torque on a non-boosted 2.4L
