flex pipe
Old Sep 11, 2010 | 09:12 AM
boose88's Avatar
flex pipe
Just took my car to an exhaust shop and he says the flex pipe is broken. He has a good reputation but wants $200 to fix it cause there is no way to get just the flex part without the entire system or something.
Would this work on the 2.4? if it does which diameter would it be?
http://www.zzperformance.com/cobalt_...=671&catid=155
I just want to get the car fixed but if its gonna cost be a lot of money to get it welded in i would consider getting something performance. Anyone else have this problem? what did u do to fix it?
Thanks
Old Sep 11, 2010 | 11:32 AM
olivecj's Avatar
You could also buy a used lsj downpipe for less than 200 bucks i'm sure. Just do another thread to see if anybody is selling a used lsj downpipe. And dont forget to check ebay as well. Good luck!
Old Sep 11, 2010 | 09:55 PM
boose88's Avatar
so the lsj downpipe will fit?
Thanks man
Anyone else have any input?
im really strapped for cash and dont wanna buy a downpipe if i can somehow get that zzp part for $16
Old Sep 13, 2010 | 02:07 AM
boose88's Avatar
help!
Old Sep 13, 2010 | 12:43 PM
RedBalt44's Avatar
$200 is alot to fix just the flex pipe. i had an exhaust leak n my flex pipe was all messed up. to fix it at an exhuast shop was just $100. just shop around for cheap prices small shops will be cheaper
Old Sep 30, 2010 | 06:49 PM
SCoBaLtC's Avatar
i just broke mines flex pipe too pay $65 to fix it
Old Sep 30, 2010 | 06:52 PM
blu3_v1p3r's Avatar
Thanks man
The LSJ Downpipe, and the 2.4 downpipe are the same.
I'm sure that that you can use that flex pipe from ZZP but you still have to cut out the ould peice and wle din the new one.
Old Oct 1, 2010 | 03:41 AM
slobalt08's Avatar
100% wrong. but you can buy flex pipes and just have a new one welded on. you can get one from zzp
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
717ssbalt
Oct 2, 2015 04:01 PM
z28addiction
Sep 28, 2015 12:03 AM
