Flywheel? Is there any aftermarket for 2.4L
Old Oct 20, 2005 | 07:22 PM
TheDriver!'s Avatar
Hey people, I noticed my rpm gauge takes awhile, ok a second or two to fall back down to idle! is the flywheel really heavy or whats the deal.. And is there a after market flywheel out there that would help the engine rotation calm down? Hope my question makes sense?? lol
Old Oct 20, 2005 | 07:24 PM
RaineMan's Avatar
I believe this has more to do with the electronic throttle than it does the flywheel... though the 2.4 is a bit slow to rev
Old Oct 20, 2005 | 07:25 PM
TheDriver!'s Avatar
geez that was quik, I'm still online hehe, would a flywheel be a good idea to upgrade though?? thanks again
Old Oct 20, 2005 | 07:31 PM
RaineMan's Avatar
I lighter flywheel would probably be a good idea.... it will help the engine rev faster but it can make the engine bog when going up large hills... I just don't know if there is one available yet.... how much.... or etc...
Old Oct 20, 2005 | 07:35 PM
97cavie24ls's Avatar
the slow rev is in part , due to the slow tach GM is now using
that and the big brother friendly drive by wire system
Old Oct 20, 2005 | 08:18 PM
TheDriver!'s Avatar
Drive by wire?? the 06SS didn't come with drive by wire did it? if it did Gm better get its act together,lol... thanks anyways people
Old Oct 20, 2005 | 10:26 PM
brentil's Avatar
He probably meant throtle by wire, which I know the Solstice 2.4L has, so I wouldn't be suprised if the Cobalt SS had it too.
Old Oct 20, 2005 | 10:36 PM
wesmanw02's Avatar
The Cobalt SS Supercharged uses a Throttle-by-wire system, not sure about the 2.2 though. I'd assume the 2.4 SS uses The TBW system since the 2.4 Solstice does.
Old Oct 20, 2005 | 10:55 PM
skoshi130's Avatar
check Gravana website I do believe they have flywheel's
Old Oct 21, 2005 | 10:10 AM
RaineMan's Avatar
Throttle by wire... yeah... I believe all Cobalts have it.... b/c when you replace the gas pedal it just unplugs from the electronic connection....
Old Oct 27, 2005 | 10:41 AM
sunburst 2.4L's Avatar
Make sure you use a lighter replacement flywheel - good idea
Someone drills or turns to lighten factory flywheel - bad idea
it can explode
Old Oct 27, 2005 | 12:59 PM
its called drive by wire , but same thing
all the cobalts are drive by wire , 2.2 2.4 2.0s/c
and a heavier flywheel will drop the rpm faster
a lighter flywheel will slow the rpm drop
and i think fidanza has flywheels for all the motors in the cobalts now
Old Oct 28, 2005 | 05:50 AM
MajesticOne's Avatar
This is true, heavier makes the rpm drop faster, but dont get confused. You want a lighter flywheel, that way you have less restriction in the drivetrain, which will free up HP. It'll make your engine seem rev'er, but when your clutch catches you'll notice how fast it'll drop compared to stock.
The only time you go heavier is when you have some serious power to lay down and you need to beable to transfer it flawlessly.
FYI: I sure you know this, but when you do a High Performance Flywheel, you should just finish the job and get a high performance clutch.
Old Nov 4, 2005 | 01:22 PM
TurboTechRacing's Avatar
The flywheels are the same on the 2.2 and the 2.4. The 2.0 is different. Both are already avaliable through Fidanza. We have them in stock.
Old Nov 4, 2005 | 10:10 PM
Ardskoay's Avatar
Would it be a bad idea to get a flywheel for an auto then? I am not sure the trans will be able to compenstate for the revs droping faster.
Old Nov 5, 2005 | 02:06 AM
aesthetics's Avatar
autos dont' have flywheels they have flex plates... so no using a flex plate instead of a flywheel is a no no
Old Nov 5, 2005 | 02:33 AM
glockglade's Avatar
Could someone tell me what this drive by wire thing is? Don't laugh just trying to learn Thanks!
Old Nov 5, 2005 | 07:48 AM
brentil's Avatar
The car uses Throttle by Wire, not Drive by Wire. Throttle by wire controls the throttle body electronicly instead of using a cable from the gas pedal to the throtle body like conventional cars. Drive by wire is where the car uses electronics to steer the wheels instead of a shaft connected to the steeering wheel.
metroplex
Sep 27, 2015 07:48 AM
jas09ss
Sep 26, 2015 01:06 PM
Extreme Dimensions
Sep 24, 2015 07:51 PM
