Forged rods and pistons for the 2.4l
Old May 22, 2006 | 05:11 AM
NJHK's Avatar
Originally Posted by mike25
well i was kiding about that level of boost..maybe 20's- to 30's possibly...and for NA you could prob get the highest compression pistons you could find and put them in there...with all the proper "alowances", you should see somewhat moderate gains from this...but i will say that the engines life will most likely be dramatically lowered
I retract my previous statement about 40+ PSI...even still 20-30 PSI is alot.
He won't find any already in production, he would have to get them custom made.
Compression would all be up to you basically. There is no right or wrong, it's all in what you think is what you need and then maintaining it from there.
Old May 22, 2006 | 05:13 AM
NJHK's Avatar
Originally Posted by savior
thanks mike, but i really wanna keep my car N.A - so whats the highest compression ratio for a Naturally Aspirated car? and what gains would i see?
Savior, hit me up privately if you need anymore n/a questions answered.
Also, Wednesday I'm getting the flash done so if you want, anyday after that you can come down and I'll give you a ride in the turbo beast
Old May 22, 2006 | 07:07 PM
savior's Avatar
njhk, ill im you when i can - this week i have off a lot and would be interested in seeing how your car performs!!!
Old May 22, 2006 | 08:57 PM
mike25's Avatar
yea after i posted that...i started thinking about the boost levels(20-30) and pretty much decided that would most likely still be to high...if not too high it would pretty much be a time bomb waiting to go off and a whole world of mechanical problems...ye i was j/k bout the 45-50..lol
Old May 22, 2006 | 10:38 PM
savior's Avatar
would replacing the cams and pistons make my car sound grumbly... like... LS1 grumbly?
Old May 23, 2006 | 01:00 AM
NJHK's Avatar
Cams alone will do that if you get ones that have enough valve overlap at idle.
Old May 23, 2006 | 10:25 PM
savior's Avatar
cute because i love the noise of the LS1
for my car (which will remain N.A) i am gonna make it breath better (i.e intake, header, exhaust) - also add a ECM tune and some new cams/piston heads
by then ill be satisfied with my car- regardless of my boostless 2.4
Old May 24, 2006 | 08:07 AM
NJHK's Avatar
It's all good, just as long as you know better now
Solaris99
28
Mar 15, 2017 01:22 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Stuff
Oct 1, 2015 05:47 PM
