Future engine plans
Old Mar 21, 2013 | 12:05 PM
klotzy_550's Avatar
Future engine plans
So I'm trying to decide what I want to do for a motor. I am possibly thinking of using my ported LE5 head on a LNF short block (giving me the option to use the E37 ECM) ditching the LNF pistons for some LSJ pistons. Then, I am not sure yet but can the LSJ's manifold bolt to the LNF or will I run into problems there. As for the flex plate, my current plan is to model it up at work and then machine out a new 8-bolt plate. For tuning I will see if I can use Moto Tron and then have the help of the entire Calibration department. Thoughts?
Old Mar 21, 2013 | 01:08 PM
09xfebalt's Avatar
Flex plate for auto? Might be best off buying hhr ss auto flex plate
Old Mar 21, 2013 | 02:17 PM
Verbatim's Avatar
Why dont you just run LE5 block, p&p le5 head. Less custom work, more torque
The LE5 is good for 400ish
Old Mar 21, 2013 | 03:49 PM
klotzy_550's Avatar
Touche, although it would cost me about 15$ to make it, and a little time to model it...either way.
My only grudge against the LE5 now is the failed sleeve. Kinda sketched me out.
Old Mar 21, 2013 | 09:13 PM
Verbatim's Avatar
Ah I gotcha; They cant be that bad, but I will find out soon with a 2.5/2.6 pulley on stock lower end.
Yes; quite a bit of auto HHR stuff should work, although I have never messed with one
Old Mar 21, 2013 | 09:21 PM
BankerBalt's Avatar
lnf is direct injection, you cannot put an lsj intake manifold on it.
Old Mar 22, 2013 | 12:05 AM
klotzy_550's Avatar
Yeah but if I use the LE5 head it becomes basically a gen 2 LSJ, and the intake mani will bolt up to the LE5 head because I've done that before.
Jan 12, 2016 12:01 AM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
Sep 27, 2015 08:53 PM
