Header n Limited-Slip dif?
Old Dec 20, 2005 | 01:43 AM
G4_mexico's Avatar
Hi
sirs... two questions here...
Regarding the Cobalt 2.4L SS....
The header that fits is the one for the 2.2L or the 2.0L ss/sc ??
also... Is ther any aftermarket Limited Slip Diferential for the 2.4L SS , or where can you get one ?
tnks
Old Dec 20, 2005 | 01:47 AM
97cavie24ls's Avatar
the 5spd uses the same basic trans as the cavalier/sunfires , and quaffie makes 1
as for the header the company i work for is planing on making 1 , i think some of the others are using the 1's from the 2.0 or the 2.2
Old Dec 20, 2005 | 04:09 AM
G4_mexico's Avatar
1,445,00 dlls ????????? OMG!
tnks anyway.
Old Dec 20, 2005 | 08:18 AM
celicacobalt's Avatar
well how much did you think the lsd would cost, they arnt cheap
Old Dec 20, 2005 | 08:58 AM
BLKSS's Avatar
Oh man lsd add on? I think you should sell your car and buy one with it factory.. That is an expensive option.
Old Dec 20, 2005 | 09:05 AM
05vicredSS's Avatar
unless you get the lsd from the factory, I say live without it, and invest the money elsewhere. unless you just have an extra 3g to burn, which most don't.
Old Dec 20, 2005 | 11:07 AM
you could spend 300-400 on a phantom grip
but the quaffie is about the best lsd out there , also its stronger then the stock diff
the phantom grip is a add-on into the stock diff , and it just puts pressure on the side gears
Old Dec 20, 2005 | 03:20 PM
G4_mexico's Avatar
soo... you would or would not recomend these ?
also que quaffle is just an insertion to the stock dif, or does it replace most stock parts inside the diff ?
Old Dec 20, 2005 | 04:35 PM
the phantom grips are ok , to me not worth the money
the quaffies replace the whole differental , only part re-used from stock is the final drive gear
worth the money yes and no , they work great (as alot of companies use them - dodge-gm-as well as others) i think they are on the spendy side , but when you compair them to others out there , they are worth the price in gold
i drove a redline with the compitition package(has the quaffie lsd), and it saved me from having to buy a wrecked redline (cause i almost wrecked the 1 i test drove because of the tire slicky shine they put on the tires) the tire rolled over and sliped in a sharp corner , and the car went side ways , and i almost hit the curb , but the quick lift off the gas and quick floor of the gas the car was able to pull it-self back straight
it was almost like i had meant to drift the car in the corner
the quaffies are a gear type lsd and apply power to the wheels differnet than the clutch style lsd's , and the spring and plates
personally i think all cars should have lsd's as optional equipment
so its your choice on which to get , the phantoms do work and alot of people use them , and they are inexpensive
my money would go to getting the quaffie though
Old Dec 21, 2005 | 02:06 AM
G4_mexico's Avatar
I'll consider that you just told me,
tnks.
Old Dec 21, 2005 | 11:24 AM
your welcome
Old Jan 9, 2006 | 07:59 PM
Dragonsfire12345's Avatar
does the extruded honed header from GM fit the 2.4L ECOTEC?
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
Cptnslo
Sep 24, 2015 09:32 AM
budah93
Sep 15, 2015 07:23 AM
