header wrap?
Old Apr 24, 2007 | 03:47 AM
paintballin_sam's Avatar
header wrap?
does anybody know how much if any more performance you would get from wrapping your header with heat insulating header wrap?
Old Apr 24, 2007 | 03:54 AM
NJHK's Avatar
There really isn't performance gains from it necessarily.
It's only used to insulate heat if NEEDED. If you're running a header (for example) that isn't coated and it causing you to heatsoak tremendously, this might be a route for you to go but you also have to think about the possibility of quicker rusting when it comes to condensation and the wrap holding it causing it to rust and deteriate much easier.
It's more cost efficient and more reliable to get a ceramic coating.
Some people use it on various turbo setups depending on certain locations because they do exceed a very high temperature but there are even coatings available for EXTREME exhaust temperatures to keep from cracking and having heat energy escaping from the header/manifold and through the exhaust system like it should be.
Old Apr 24, 2007 | 04:34 AM
InfinityzeN's Avatar
If you want to wrap something, consider a wrap on your intake tubing. That'll drop your charge temp by 5~10 degrees.
Old Jul 7, 2016 | 05:29 PM
jg123boss's Avatar
Header wrap
Is it a bad idea to wrap stainless steel headers scince there not supposed to rust? Its very dry around here
Old Jul 7, 2016 | 05:59 PM
Holy 9 yr thread bump.
The rusting out issue really isn't a problem unless you get them wet and let them stay wet. Since they're hot the water doesn't really get down to the metal, humidity changes or extreme temp swings can cause some condensation, but again they're hotter meaning it won't condense there.
Old Jul 7, 2016 | 06:13 PM
jg123boss's Avatar
Lol its a 9year old thread just hoping id get someone eles opinion on wraping stainless headers im just trying to keep the heat from melting/getting anything hotter than its supposed to be
Old Jul 7, 2016 | 10:40 PM
It shouldn't be an issue on most ecotecs, you can always install some heat shielding before header wrap, or you can send the header out to get ceramic coated. It's pretty cheap and lasts and looks better than exhaust wrap.
Old Jul 9, 2016 | 01:44 PM
Foximus's Avatar
we've wrapped both headers that have been on the race car, adn even after one got soaked in water and coolant, no issues.
Old Jul 9, 2016 | 06:20 PM
jg123boss's Avatar
I think im going to try the header wrap scince its already on its way in the mail
Old Jul 9, 2016 | 09:48 PM
jg123boss's Avatar
Nice im just trying to keep the heat down once i install the headers cause my temperature already runs at about 195-200
Old Jul 9, 2016 | 09:49 PM
jg123boss's Avatar
Are you talking about that gold heat resistant tape
Old Oct 21, 2023 | 06:12 PM
ArokOleary's Avatar
7 Year Thread Bump!! Anybody have any observable results? I'm Flame-Proof painting my header now then wrapping with Titanium wrap.
jcalvin1126
Oct 26, 2015 12:31 AM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
budah93
Sep 15, 2015 07:23 AM
