Help: Want to hit 200hp.
What is the cheapest way possible to surpass 200hp? I want to free up exhaust flow but the last thing i want is a loud annoying exhaust, and I don't wanna get a tune just yet seeing as the only performance mod i have is a K&N Typhoon.
You can do:
intake manifold
exhaust manifold
downpipe
cat back exhaust
intake
smaller pulleys or light weight pulleys
water or meth injection
nitrous
not much beyond that for NA thats cheap and makes big power.
You can do:
intake manifold
exhaust manifold
downpipe
cat back exhaust
intake
nitrous
light weight pulley
http://mrzperformance.vstore.ca/prod...roducts_id/144
underdrive
http://mrzperformance.vstore.ca/prod...roducts_id/143
I would do your own research to see what belt size is needed for a under drive pulley and if they are safe to run....
underdrive
light weight pulley
underdrive
underdrive
Search my friend. I've heard of people changing the underdrive pully (on an SC or TC), and it caused problems. So swear to it, while others say it will cause more problems. Do some research and i'm sure you can find your answers.
as someone said
Slow down and do a lot of research. Do you want to invest thousand in the motor or do you want cheaper power. Because a turbo/supercharger are the cheapest route to big power.
Besides nitrous of course, but even then, you risk snapping rods and burning up pistons.
you live in elgin eh? is it a place around here? maybe you could ask your friend how much it'd cost for a regular customer?
I know when I had my car, a Injen intake, ported TB, cobalt addiction header and highflow cat and a2.5 magnaflow exhaust and my tune I laid down #186 HP on a mustang dyno... with a little head work I know my old car would have put two hundred down no problem
#200 is doable but you just have to piece your build together and get a good tune
IMHO , if you want to do anything to the LE5 a tune is a requirement..... because even with just an intake I logged several LE5's at well over 100% IDC's....... not saying you can't get away with out a tune, but with trifrectica and HPT out there you have options.
Well Op said cheapest way possible... not cheapest without boost. Looks to me like you either spend 2G's on boost or spend about the same on all the little upgrades listed above^^ comes out bout same spent
