How does VVT work?
If he had actually read what you posted he would have known that. I learned that unlike VVT, VTEC switches between two different cam lobes depending on the RPM hence the "kick". Also i-VTEC can alter intake timing continuously in addition to what VTEC already does. I could go on and on about what I learned.
#38
No way did you just bump this thread. Here's your answer: http://en.wikipedia.org/wiki/Variable_valve_timing and http://auto.howstuffworks.com/camshaft2.htm
#41
#42
VTEC (Variable Valve Timing and Lift Electronic Control) is a valvetrain system developed by Honda to improve the volumetric efficiency of a four-stroke internal combustion engine. This system uses two camshaft profiles and electronically selects between the profiles. It was invented by Honda R&D engineer Ikuo Kajitani.[1] It can be said that VTEC, the original Honda variable valve control system, originated from REV (Revolution-modulated valve control) introduced on the CBR400 in 1983 known as HYPER VT EC.[2] VTEC was the first system of its kind, though other variable valve timing and lift control systems have been produced by other manufacturers (MIVEC from Mitsubishi, VVTL-i from Toyota, VarioCam Plus from Porsche, VVL from Nissan, etc).
#43
Thats interesting...I didnt know that either. I'm curious to know where you got that info from because everywhere I have read on the internet always displays info along these lines...and its weird that this search turned up nothing about GM...
o well...w/e
#44
Fiat was the first auto manufacturer to patent a functional automotive variable valve timing system which included variable lift. Developed by Giovanni Torazza in the late 1960s, the system used hydraulic pressure to vary the fulcrum of the cam followers (US Patent 3,641,988). The hydraulic pressure changed according to engine speed and intake pressure. The typical opening variation was 37%.
In September 1975, General Motors (GM) patented a system intended to vary valve lift. GM was interested in throttling the intake valves in order to reduce emissions. This was done by minimizing the amount of lift at low load to keep the intake velocity higher, thereby atomizing the intake charge. GM encountered problems running at very low lift, and abandoned the project.
Alfa Romeo was the first manufacturer to use a variable valve timing system in production cars (US Patent 4,231,330). The 1980 Alfa Romeo Spider 2.0 L had a mechanical VVT system in SPICA fuel injected cars sold in the United States. Later this was also used in the 1983 Alfetta 2.0 Quadrifoglio Oro models as well as other cars. The system was engineered by Ing Giampaolo Garcea in the 1970s.[2]
Honda's REV motorcycle engine employed on the Japanese market-only Honda CBR400F in 1983 provided a technology base for VTEC.
#45
#47
vtec is 2 sets of cam lobes hydraulically actuated at 4000 rpm's. it's a higher lift and more aggressive timing. vvt is a hydraulically actuated cam timing control. doesn't change lift.
#48
yeah you're right about that but fiat isnt GM and honda may not have invented it but honda apparently made it simpler and was one of the first to prooduce it on ecomony cars and every other car manufacturer out there just about has tried to copy it by designing something almost exactly like it. oh well
#50
Acually all in all BMW held design vtec first n vvti is nothing live vtec it's more like venos I guess it uses cam phasing to advance or retard a cam hense why we do not have a egr
