How does VVT work?
Old Nov 15, 2009 | 03:53 AM
  #51
ff_drift_lol's Avatar
right it leaves the exhaust valve open for a split second during the intake stroke serving the same purpose as an egr system
Old Nov 15, 2009 | 11:58 AM
  #52
riko540's Avatar
Originally Posted by Acey
Yeah the actuation RPM varies depending on the motor... I think on older Si's it used to be like 5800
I think the newer ones are at either 5600 or 5800 too.
Old Nov 15, 2009 | 01:55 PM
  #53
my bad, I should have said that.
Old Nov 16, 2009 | 10:18 AM
  #54
Red07SSNA's Avatar
The VVT in the ecotec does not affect valve lift or duration -- these stay the same. What the VVT does do is change the camshaft relationship with the crankshaft. Think of it as an automatic sprocket adjuster -- the cams move back or forward to advance or retard up to 60 degrees at the sprocket. In technical terms it changes the intake and exhaust camshafts' lobe separation.
Old Dec 7, 2009 | 08:51 PM
  #55
rtullos808's Avatar
To answer your question... VVT doesn't "kick in". It's not VTEC. Read up in those links I posted, it'll take you 5 min and you'll have a vastly greater understanding
yeah see thats the one problem with this website, right here. there is nothing wrong with sharing knowledge, but if your an arrogant pompus ***** while you do so, then your gonna **** people off in the process. that guy clearly mentioned that he didnt know much about VVT. i know lots of **** too, about a lot of things, but i dont need be a sorry ******* or treat people like they are stupid just because they dont have knowledge about this or that. i hop this site can clean up this behavior, even at the risk of 86ing someone knowledge.
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
jmelton327
Sep 26, 2015 10:04 PM
