how long to install crank pulley?
Old Oct 19, 2006 | 03:47 PM
UpOnGaMe's Avatar
So around how long will it take to install a crank pulley on these motors on a cobalt...........
Old Oct 29, 2006 | 10:53 PM
panblackrose's Avatar
depending on wether or not you have to move the engine around to reach it. havent looked at it, but it is a good question. I was considering ordering a lightened, smaller diameter one from GM performance or some other place, reduce some of that drag
Old Oct 30, 2006 | 02:14 AM
bigworm's Avatar
install time is minutes. you need to remove the cover peices and the old pulley. i think the main bolt is 21mm, so make sure you have that and a 15mm wrench for the belt tentionor, very simple process. Also, worsecase, you'll also need a pulley-puller, they are cheap.
search around, theres lots of how-to guides.
Sep 30, 2015 07:22 AM
cw383
Sep 30, 2015 12:41 AM
z28addiction
Sep 28, 2015 12:03 AM
ChrisTutoki
Sep 24, 2015 08:39 PM
