I'm So Angry...
I'm So Angry...
I started my downpipe installation at 10 this morning. Here I am and the downpipe still isn't done. I haven't even gotten the stock downpipe off the stock header. I've gotten two out of three bolts off the stock header connected to the downpipe and one is stuck on. I have a final and have to go to class and will finish the installation when I finish. On the way to class, I'll be running an open downpipe. I have no choice. I didn't think it would take this long, but it has. Anyone have any suggestions to get the last bolt loose off the stock header connected to the downpipe? I've sprayed WD-40 on it and tried every angle. If it helps, it's the bolt on the lower driver side.
How much are air tools? Just curious, 'cause I tend to just slide across the floor sometimes haha
Gotta get EEZE too haha. Where? Pepboys? Wal-mart?
Last edited by Billig ss/sc; May 13, 2008 at 04:13 PM. Reason: Automerged Doublepost
all these suggestions require driving to a store, locating products, and testing which ones work...
The first tool ever used was a big ass stick. Why? When it comes down to it beating the holy #$%!@% out of it does the job.
No... I used one when I did my DP. You obviously can't have a 3 ft long cheater bar... but a good 6-12" can help out a ton.
That, or go to Lowe's and buy a LONG breaker bar. The longer the bar... the less effort it requires out of you.
