I'm So Angry...
Old May 13, 2008 | 04:29 PM
lil_kano's Avatar
Do you have access to a drill with different tourqe levels? Like the thing you twist around the tip; usually ranging from 0-20 or someting of the sort? That'll crack it loose. just use an extension.
Old May 13, 2008 | 04:32 PM
bluechevycobaltss's Avatar
when all else fails for me i break out the dremel (sp?) and get to cuttin
Old May 13, 2008 | 06:05 PM
Cloudio's Avatar
dood go to walmart or home depot what have you and by liquid wrench the **** penetrates metal unlike wd-40 which only lubricates
spay on the bolt all over wait 2 minutes and the bolt will come off like its a joke
Iam serious dont even waste your time with anything else
THIS IS YOUR SOLUTION
END THREAD
Old May 13, 2008 | 06:07 PM
D4u2s0t's Avatar
Don't use WD-40... use PB Blaster. Connect your socket and get a cheater bar. Nothing can stop a cheater bar.
i use the end of the pipe for my floor jack. works like a charm for those hard to break bolts
Old May 13, 2008 | 06:10 PM
Psykostevo's Avatar
Use LEAD BLASTER....it works way better than WD-40
An electric drill is going to take that off? Come on!
Last edited by Psykostevo; May 13, 2008 at 06:10 PM. Reason: Automerged Doublepost
Old May 13, 2008 | 06:13 PM
nightstalkercars's Avatar
why not just cut the head of the bolt off and buy a new bolt? use a small grinder
Old May 13, 2008 | 06:15 PM
chad463's Avatar
Mine were stuck and I used liquid wrench, waited 5 minutes and then voila they came off.
Old May 13, 2008 | 06:17 PM
Cloudio's Avatar
as i said! theres (1) person to back me up
Old May 13, 2008 | 06:24 PM
the_rainmaker's Avatar
except breaking your wrench.
Old May 13, 2008 | 06:33 PM
Brandon97Z's Avatar
torch? If you have one of those hand held propane torches that might do it.
Old May 13, 2008 | 07:52 PM
  #36
YzRider452's Avatar
Yea, liquid wrench is the same as lock eeze.
Old May 13, 2008 | 07:59 PM
  #37
Sunburst_SS's Avatar
liquid wrench works wonders...works better then PB Blaster IMO
Old May 13, 2008 | 09:18 PM
  #38
lil_kano's Avatar
Yeah it act just like an impact tool. All you need is to crack the bolt loose . Thats how I got mine off and thats all I gotta say.
Old May 14, 2008 | 05:55 AM
  #39
USMCFieldMP's Avatar
Rattlesnake Race Shop
Usually the Bolt breaks first
If your wrench breaks... then you bought some CHEAP ****.
Old May 18, 2008 | 05:43 PM
  #40
Turbo06Sedan's Avatar
funny thing is, my tools from walmart have outlasted my friends MAC Tools...and costed about $200 less.
Use a cheater bar (aka a pipe)... Liquid Wrench is the ****.
LittleMT
Mar 29, 2008 01:05 AM
