Injector Question
Old Sep 30, 2010 | 06:04 PM
matthud's Avatar
Injector Question
Can the LE5 fuel rail be used on the L61 motor with the L61 injectors? Is there any difference between the injectors on the LE5 and L61?
Old Oct 9, 2010 | 12:36 AM
matthud's Avatar
Old Oct 9, 2010 | 12:47 AM
Spanky's Monkey's Avatar
zzp sells the same inj to 2.2 guys as they do the 2.4 so that answers that. as for the rail i'm sure it will work but why swap when the inj's will fit either rail.
Old Oct 9, 2010 | 01:08 AM
matthud's Avatar
I have a rail from the LE5 that I brazed an AN fitting onto, that I want to use on my L61. I couldn't find a L61 rail at the yard so I had to grab the LE5 rail, which was easier to put the fitting on due to the larger end on it.
Old Oct 9, 2010 | 01:14 AM
sounds like you're ready to test it out then.
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
