Injen CAI ---- Worth it?
Old Aug 24, 2006 | 06:45 PM
Co|3aLt $$'s Avatar
Chevy racing exhaust w/ the chevy Extruded Honed Manifold. I dont have any dynos or anything, I'm just going off of what the stock HP is and adding what the exhaust should be giving me. Also, a stock SS/SC has to at least work to get past me, (they do eventually ) so I know I'm not too far off, and the numbers match.
Old Aug 24, 2006 | 06:47 PM
YoAdrian's Avatar
What exactly is the Extruded Honed Manifold? A header?
Just curious because I am about to add a magnaflow cat and was thinking about header also.
Old Aug 24, 2006 | 06:51 PM
Co|3aLt $$'s Avatar
here check this out, it's a good site to find most of the chevy products offered for cobalts. This is a direct link to the part. http://www.crateenginedepot.com/Coba...P1381C146.aspx
Good luck, the exhaust rocks, and it sounds awesome. I have a crappy lil vid here somewhere!
Old Aug 24, 2006 | 06:52 PM
D4u2s0t's Avatar
you don't have anywhere near 190hp with just an exhaust... unless you're talking about at the crank... exhaust maybe adds about 8 hp or so... and there's NO bolt on that will give you about 20 hp... not even close to it... if you get exhaust, intake or air box mod, header, downpipe with high flow cat, that will probably add about 20 hp give or take...
Old Aug 24, 2006 | 06:56 PM
shortyheldberg's Avatar
it's a manifold that has been opened up and polished for smoother flow helps decrease any thing that will restrict exhaust flow. also he is only going by what is said 170 + + just adding up for a round about number
Old Aug 24, 2006 | 07:00 PM
Co|3aLt $$'s Avatar
well, I guess since I should be around 180HP then maybe I will just wait for the 2.4L CAI, and grab that. I would like to take a look at that down pipe w/the high flow cat. Any suggestions?
Old Aug 24, 2006 | 07:03 PM
YoAdrian's Avatar
So if I go with a high-flow cat, is an upgraded downpipe necessary?
Old Aug 24, 2006 | 07:05 PM
D4u2s0t's Avatar
it's not, but will require some welding into the stock downpipe... you'll have to have the cat cut out, and the new one welded on... if i understand correctly, the downpipe is the most restrictive part of the whole exhaust... it will help, but if you really want to make a difference get rid of the stock downpipe...
Old Aug 24, 2006 | 07:24 PM
YoAdrian's Avatar
I was going to do just that- cut out the old one and weld in the new cat. I guess if I am going to go through the trouble of replacing the cat, I might as well get an upgraded downpipe. Anyone have suggestions for a good downpipe at a decent price?
Old Aug 24, 2006 | 07:30 PM
joeworkstoohard's Avatar
yea... these airboxes arent' that bad, and that resinator under the wheel well is the most restrictive part of it... when you look at it, you'll see what i mean... it comes off pretty easy, it's not really connected by anthing than clips that pull right off... much better throttle response if you take it off...
so, to see what would happen, i went out and ripped that damn thing off... then i took a video of the result... go me.
if anyone cares...
https://www.cobaltss.net/forums/show...785#post454785
Old Aug 24, 2006 | 07:38 PM
  #36
D4u2s0t's Avatar
if anyone cares...
haha, nice!! see how it's louder at wot? especially around 3 -4k rpm
Old Aug 24, 2006 | 07:40 PM
  #37
yeah, it sounds a LOT better while in the car running down the road... but that's kinda hard to get on video in the driveway.. maybe i'll make my brother come along and film a road test.
Old Aug 24, 2006 | 07:47 PM
  #38
D4u2s0t's Avatar
yea... not moving you don't really get the good effect...
  #39
D4u2s0t's Avatar
with a K&N it will be a little louder and a little better response too...
Old Aug 24, 2006 | 07:49 PM
  #40
WSFrazier's Avatar
I doubt you at 190. We just dynod a 2.4 @ 150 with a 2.5" exhaust, injen cai, and custom tune.
BTW where in PA are you located?
Old Aug 24, 2006 | 08:22 PM
  #41
avro206's Avatar
It sounds great AND does add hp and increase performance.
I hate to beat a dead horse but I have track tested my car before and after install of SRI Injen.
The car ran 0.1 and 2 mph faster.
It's a small increase, yes but it is noticeable and pretty cheap.
Just do it
Old Aug 24, 2006 | 08:28 PM
  #42
Co|3aLt $$'s Avatar
well first of all, joe I am gonna do just that, take out that resonator. That will give me the sound, as if I'm correct you have a stock exhaust, and it sounded pretty nice. I would imagine the exhaust I have will benefit from this as well? anyway, WSFrazier, I am near Stroubsurg PA ( I actually live in a rural area, but S-burg is the nearest major town I guess ) It's northeaster, you could mapquest it if you were more interested. That sucks though about the 150HP, but hell I love driving the car so oh well! lol
Old Aug 24, 2006 | 09:33 PM
  #43
here, i added an in-car clip.
Old Aug 24, 2006 | 10:21 PM
  #44
Bandit2941's Avatar
Just do it
Avro, what were the density altitudes like when you gained the .1 and 2 mph?? That's quite a bit if it happened at the same D.A........
Jan 12, 2016 12:01 AM
717ssbalt
Oct 2, 2015 04:01 PM
SSLOW06
Oct 1, 2015 07:21 PM
Sep 27, 2015 08:53 PM
