intake tubing
Old Nov 14, 2011 | 12:25 AM
GRok25's Avatar
intake tubing
ok i have a k&n intake and i also have the zzp throttlebody spacer with the lsj throttle body.
now i noticed after i put the zzp spacer on the angle of the k&n flex pipe is smaller because of the added hight of the tb and it is under more stress.(its rubber so it streches).
since the pipe is bent more less air is getting to the throttle. so is it more benificial to keep the larger tb but have the pipe bent more or just to have the intake alone?
Old Nov 14, 2011 | 01:46 AM
GRok25's Avatar
Old Nov 14, 2011 | 08:29 AM
noorj's Avatar
cant really tell what your trying to say, the 90 degree bend into the throttle body on the intake it bent? pics would help. but absolutely no, if it is bent it is disrupting and limiting airflow. the injen has a metal piece for the 90 degree bend, you may want to look into that
Old Nov 14, 2011 | 12:40 PM
nhanson's Avatar
you have a spacer on top of the adapter plate or is the spacer your adapter plate?
make sure you 90* coupler is 3 in.
Old Nov 14, 2011 | 09:58 PM
GRok25's Avatar
no only the adapter plate
Old Nov 14, 2011 | 09:59 PM
GRok25's Avatar
the k&n bend coupler is rubber unlike the metal injen one so it can flex
Old Nov 15, 2011 | 12:26 AM
nhanson's Avatar
i have a 3 in. 90* and my liner under the hood hits and bends it down a tad...doesnt really affect it
Old Nov 17, 2011 | 12:48 AM
cobalt_sport08's Avatar
Could you tell any difference in power when you got the LSJ TB and the intake?? I'm thinking about doing this..
no_ss
Oct 18, 2015 11:58 PM
yellow dragon
Sep 28, 2015 09:49 PM
z28addiction
Sep 28, 2015 12:03 AM
