JBP VVT LE5 Camshafts
#129
Originally Posted by Allshot
Mike if you want to come down to northern cali we can run em.
#130
I think with the cams header downpipe and tune you should put up a good fight. I know I was in big worms 2.4 and he had the header downpipe exhaust and tune and his car felt like it hauled *****
#131
...I know I was in big worms 2.4 and he had the header downpipe exhaust and tune and his car felt like it hauled *****
however, the 54 trim is on the way =]
#134
Originally Posted by 2K5SS/SC?
Great to hear it's fixed. I thought it had to do with the cam sensor or timing. I want to see numbers now.
#135
that sucks, we're all glad to see things are moving forward and i cannot wait to hear that results from the cam swap. will be checking in all the time for the updates.
#136
Originally Posted by g5mike
not all fixed,ended up taking it to a performance shop,my buddy had everything ass backwards
#138
I think he means that the crank in relation to the cams is off. The cam gears and cams should be marked prior to removal. The problems with replacing the cams is you loose that mark, and if everything is not spot on with the new ones, all the valve timing will be off = very bad.
#140
I think it's also misleading to think that it's easy just to swap out the cams because the way they sit on top of the cylinder head -- looks like a simple remove and reinstall. The timing chain is rather complicated with the balance shafts and "serpentine-like" routing -- I think it would be safer to pull the front cover off the engine to double check that the timing chain is lined up and timed properly when swapping out cams, IMO.
#141
I'm sure you've heard of 2 identical engines coming off the assembly line with 2-3hp varience between them? This is most often the result of normal variations in cam timing from the factory.
#142
I would be more than concerned about bent valves at this point.
Also very concerned that any feedback following this fiasco should be taken with a grain of salt. There were no baseline dyno tests and HP "claims" are much higher than should be realistically expected.
#143
G5mike, do you have any 1/4 or 1/8 mile times to compare against? Or, have you raced a friend that you just barely beat or that just barely beat you that you could race again so we can use it as a reference to compare performance gains?
Inquiring minds want to know.
#144
#145
Originally Posted by sushidog
Good point.
#146
Mike, thats terrible news. Have the shop perform a leak down test on cyl #1 with the camshafts rotated at TDC (not 60 deg b4) and ensure that both exhaust and int. cams are not actuating the valves. Hopefully, your going to be about 80% or higher... If not, then the head has to come off.
Timing on the ECOTEC engines is something thats very very sensitive. Even dealers screw this up... You really have to know what you're doing.
#147
