"L" gear in the auto trans... is it first gear only?
Old Jun 21, 2006 | 12:47 PM
05YELLOWSS's Avatar
Wow this is absolutely the most interestng thing I have read in a while...who woulda thought you auto guys would come up with this stuff, that really cool!
Old Jun 21, 2006 | 01:09 PM
ReggaeRampage's Avatar
If you do this one too many times, is there a high risk in messing up your tranny tho? If it changes gears on its own, I wouldn't imagine it would.
Old Jun 21, 2006 | 02:33 PM
RaineMan's Avatar
Wow... way to revive a dead thread.
Running it hard like that can be bad for the tranny... if you do it a lot... just save it for the track... you'll be fine.
Or invest in a tranny cooler.
Old Jun 28, 2006 | 10:36 PM
sethallen's Avatar
[QUOTE=SilverStreak]Wow... way to revive a dead thread. QUOTE]
yea you're right...
by this time I've already gotten rid of the 2.4 and picked up my ss/sc.....lol thanks for the help 3 months later when it is no longer appicable
Old Sep 13, 2007 | 07:15 PM
LSDriver10's Avatar
I have a 2.2 and i have L and I as well although im not sure how it all goes thats why im on here
Old Sep 13, 2007 | 07:29 PM
olivecj's Avatar
I had my g5 gt in L gear today for the first time. The car flew off the line and spun tires like crazy but I also forgot to upshift through the rest of the gears so i just let off the gas and stopped on the side of the road and put it back in drive. Like everybody said just keep it in drive for regular driving.
Old Sep 13, 2007 | 08:01 PM
wordsthatiwrote's Avatar
Originally Posted by ecoteched
I looked at my shifter today and instead of an L or an I. I have 1 and 2!?
According to your sig. It shows you have an LS. Maybe thats why. You have a 2.2 instead of the awsome 2.4 which everyone else has..... JK but seriously, i think it is cause of the motor difference
Old Sep 13, 2007 | 09:35 PM
cobalt15.7's Avatar
the 2.2 goes to redline in first, shifts to second and if the 2.4 is getting cut off at 73 and i know for a fact many times over that the 2.2 will hit 80 before doing its bounce off the wall thing. if you want to avoid this and it will save you alot of time shift about 10mph before the shift because if you wait to late it will still do it. this happenend to me at the track it cost me about half a second.
Old Sep 13, 2007 | 11:09 PM
avro206's Avatar
Originally Posted by tivie85
L is actualy 1st and 2nd. No TC, lower ratios. However a trick is this, goto L's 2nd gear, shift it to I to change to 3rd, and then back to L. it will take off tc.
lower ratios? They trans has fixed gear ratios...only CVT has variable.
L does nothing for performance--it just turns the traction control off. I just gives you a little engine braking.
Old Sep 14, 2007 | 10:03 AM
Evil C's Avatar
it turns off TC and lets you rev higher in the power band in that sence yes it does do somthing for your performance. Dosent net you more poneys but it is a quicker ride than letting the auto do it its self.
Old Sep 14, 2007 | 02:58 PM
  #36
celicacobalt's Avatar
agreed
Old Sep 14, 2007 | 04:00 PM
  #37
GTP's Avatar
GTP
I also have a Saturn VUE 3.5 Liter V6 250 horse/ 250 ftlbs and I always thought it was a little doggy for the power it had. When in L it shifted at a measely 5500 and dropped itself out of VTEC (HONDA V6).
Then I stumbled across the secret to GMs tranny. If you leave it in L or I. It doesn't shift any different than if it were doing it itself.
However, when you manually shift it, you're able to bring the V6 up to 6500rpm (Only in 2nd gear) if you time it right. Too late, and you'll bounce the limiter
Launch in "L," to defeat traction control shift into "I." By shifting into "I" you allow the car to shift into 2nd with a higher redline (6000rpm in 1st gear for the VUE) higher for a Cobalt for anyone trying it. IF you leave it in "L" for the 1-2 shift, it will shift at a much lower RPM unless you are tuned (DanSpec).
Once in 2nd gear (after it shifts) , drop the shifter back into "L" again, hold it to almost redline and shift into "I" once again. It should shift right around (6500rpm for the VUE) and drops me into 3rd gear VTEC...well no VTEC for cobalts but the change in accerlation times are AMAZING.
Just some tibits to helop autos without tune. Hope it helps.
Old Sep 14, 2007 | 07:52 PM
  #38
Evil C's Avatar
yeah after i get a header im getting it tuned. Worst auto tranny tune ever stock seariously turds out the car.
Old Sep 14, 2007 | 08:35 PM
  #39
Blood Lucky Picnic's Avatar
haha...yeah...that good old "L" is pretty fun.
Old Sep 16, 2007 | 01:06 AM
  #40
yoppzilla's Avatar
yeh Id rather GO L first and halfway through secound and hit *I* to 3rd then D then a nice drop back to *I* will boost ur rpms back up and gain somenice speed then loosin her up backinto D, Try Shifting from D to I while for slowwing down also/when it hits 35 its a real hard down shift btw, all this is old news but staying L to 75 probally not as good as an idea
Old Sep 16, 2007 | 01:25 AM
  #41
tonio5555's Avatar
The the drag racing forums Halfcent gave a great write up on launching thr automatic.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
bigdeertz
Nov 17, 2016 09:41 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
DocSvensk
Sep 27, 2015 02:24 PM
