launching tips...
Old May 2, 2006 | 05:57 PM
mike25's Avatar
launching tips...
what is the best rpms to launch at...and when i do should i immeadiately shift into 2nd or run through first and then into 2nd...sorry for the dumb question but i am new to the whole manual tranny thing
Old May 2, 2006 | 05:59 PM
Tomtwtwtw's Avatar
You talking about racing or getting groceries?
Old May 2, 2006 | 06:21 PM
Mines_Better's Avatar
i launch at about 1500-2000rpms. i dont floor it until im already going about 15mph. then once i floor it i take it up to redline and powershift into 2nd(shifting without letting off the gas). then its smooth sailing from there.
Old May 2, 2006 | 06:30 PM
TXRLU's Avatar
What's that smell??? Oh its Evan's clutch...........
Old May 2, 2006 | 08:38 PM
Brenn8402's Avatar
haha
Old May 2, 2006 | 09:24 PM
mike25's Avatar
i dont mean everyday driving i mean racing
Old May 2, 2006 | 09:31 PM
Brandon97Z's Avatar
I launch between 2-2.5k easing off the clutch giving a little more throttle, once i feel the tires start gripping, off the clutch, mash the gas. Of course best i've gotten to date is a 2.28 so i'm still workin on it myself.
Old May 2, 2006 | 09:37 PM
Dragonsfire12345's Avatar
what about automatic?
Old May 2, 2006 | 09:39 PM
haha i think thats vaughn's clutch remember??? im the one pulling the 2.1 60' times on stock tires.
Old May 2, 2006 | 09:40 PM
Brandon97Z's Avatar
And shift right at redline. The more pratice the more time you'll shave off.
Old May 2, 2006 | 10:26 PM
jerryg's Avatar
im with brandon. just remember the race track is much more diff you gripp way better. the more you race the better you get.
Old May 2, 2006 | 10:42 PM
Tomtwtwtw's Avatar
Mash the pedal on the right.
Old May 2, 2006 | 10:45 PM
ptparker's Avatar
Thats exactly what I do, As soon as the first light comes on, I blip the throttle to get it to 1500 to 2k and then launch on the last yellow. The key to no wheel hop is to hold the throttle at 70-80 percent until about 3 or 4k, and then smoothly go to the floor as you go to second gear, And you have to back off the throttle a little (not quite a 'true' powershift) or else you will just bounce off the revlimiter and the clutch won't catch the gear.
Old May 2, 2006 | 10:49 PM
05REDROCKET's Avatar
Not that simple maybe in an auto.
Old May 3, 2006 | 08:40 AM
oaklandmr's Avatar
When I did it, I held it at 2k and let it go then once it started to pull good, I mashed it and I got a 15.7 out of it.
Old May 3, 2006 | 09:36 AM
MARIN007's Avatar
On the track I held around 2500rpm, dropped clutch and immediatly mashed it. Gave me 2.1 60' and 15.04
Old Nov 4, 2006 | 03:11 PM
116Fanatic's Avatar
FOr an automatic, put your shifter into 1st gear to turn on the TCS, hold the brake all the way, punch the gas all the way, and release the brake when you're ready to go. Don't forget to shift back up to drive after 1st gear. All you really need it for is the TCS.
Old Nov 7, 2006 | 06:15 PM
redSS2.4L's Avatar
Really stupid n00b question, but how do you shift w/o using the clutch? I've heard of people doing that, but never have figured how/when, because I didn't want to grind gears while experimenting, lol.
Old Nov 7, 2006 | 06:20 PM
NinjaHampster's Avatar
very simple you just bump it into nuetral
Old Nov 7, 2006 | 06:28 PM
R&C_rallySS's Avatar
My best launches have been in best results in the 1/4th mile. I think it is one of the most important parts of a front wheel drive car, or any vehicle for that matter. With this said I have fond flooring it through first gear will do nothing but spin and you won't travel anywhere quickly. I feather the clutch and launch @ 1600 rmps. Once I feel the car grabbing I go FT and crack second @ 6300 rpms. I wind second gear out as long as possible. Must not hit the rev limit. If you crack into 3erd gear right before you hit the rev limiter you will have a very good 3erd gear pull. I ride 3erd gear out the rest of the way in the 1/4th. The biggest problem for me at the race track is should I shift into 4th or not. On my best times third gear runs into the rev limiter right as I hit the 1/4th mark. Somtimes it doesn't which means I have to shift into 4th gear.
Old Nov 7, 2006 | 06:36 PM
martinsmu's Avatar
R&C Rally, get the gmpp stage2 and that will give you the extra 500rpm to play with ... The car is alot stronger and the extra 500 ropm is wonderfull!! And GM will back up your car 100%
Old Nov 7, 2006 | 10:26 PM
redSS2.4L's Avatar
Then how does it work going into the next gear w/o the clutch? (If I'm not mistaken, I believe that you can do that?)
Old Nov 8, 2006 | 04:48 AM
CobaltChikara's Avatar
well...can't go into first without the clutch..im sure we all know that. But to shift without the clutch you gotta be going the right speed for the gear. Once you're at the right speed just pop it in, and if it's correct, it should go in smoothly. I tried it a few times before, and i think from first to second i did it at around 15mph, second to third at about 25mph, and third to fourth around 35mph. Just play with it a few times to see. Be warned, you may grind the gear the first couple times. If you start to hear that grinding sound, don't force it.
Old Nov 8, 2006 | 07:10 PM
redSS2.4L's Avatar
Alright, thanks for the info.
Old Nov 8, 2006 | 07:50 PM
diablo2007's Avatar
thats mostly with hondas and eagle talons that i have heard of doing that, please dont do it in the cobalt...ahhhh its warrentied go for it!
