limp mode
Old Jul 23, 2008 | 12:53 PM
mike25's Avatar
limp mode
what would it take for the car to hit limp mode? just wondering
Old Jul 23, 2008 | 12:54 PM
Raven SS's Avatar
mis timed...i know this all too well
Old Jul 23, 2008 | 12:55 PM
Kibosh3's Avatar
everything cool, mike? :|
Old Jul 23, 2008 | 12:56 PM
CobaltDude06's Avatar
could be a senser gone bad thats what put my car into limp mode once
Old Jul 23, 2008 | 12:57 PM
mike25's Avatar
would lets say hitting boost untuned for a short period of time cause this?
Old Jul 23, 2008 | 12:59 PM
Raven SS's Avatar
possible...mostly ive seen it happen when the car is under major load for example...when my cams were mistimed everytime i hit a hill and tried to drive up a minor ascent (not even a hard climb) it would go into limp mode...ive seen people run pig rich and go into limp mode randomly...
if u dont have ur throttle sensor plugged in i know u will go in limp mode...just cases ive seen other than that haha idk
Kibosh3's Avatar
Old Jul 23, 2008 | 01:03 PM
pjk91's Avatar
if the car has a theftlock malfunction while the engine is running, engine power is reduced in all gears. happened to me a few times. you will know because the theftlock symbol is on.
Old Jul 23, 2008 | 01:05 PM
mike25's Avatar
what does it take to get out of limp mode
Old Jul 23, 2008 | 01:06 PM
Jesse_Chouinard's Avatar
Mine went into limp mode when the cat went
Old Jul 23, 2008 | 01:08 PM
Raven SS's Avatar
depends on how bad the limp mode is...when mine was mistimed..i just shut it off and waited 2 mins and restarted...the tps one had to be fixed before car would come out and the running rich the battery needed to be pulled and then put back in
Old Jul 23, 2008 | 01:20 PM
mike25's Avatar
you mean unhooked? will the car still move in limp mode
Old Jul 23, 2008 | 01:23 PM
Raven SS's Avatar
yea i think 40 is the fastest u can go?! and yes it wasnt clipped in all the way
Old Jul 23, 2008 | 01:54 PM
SS4EVER's Avatar
My buddy's GLI went into limp mode shortly after we had just installed a turbo-back exhaust.... What ended up causing it to go into limp mode was actually a screw on the waste-gate that loosened and caused the wast-gate not to build up the back pressure... He had to drive it for a weekend w out any boost... but it ran fine... just w out boost...
Old Jul 23, 2008 | 02:00 PM
bowtie32's Avatar
I was in limp mode when i was running too lean, once my MAF went over 12, check engine light came and limp mode was on.
InfraRedline
Drag Racing
35
Sep 29, 2015 02:09 PM
speedlimit
Site Development and Help
Sep 25, 2015 08:04 AM
Dustonian131
Sep 23, 2015 08:03 PM
bucks121
Sep 12, 2015 07:39 PM
