a little sumthin for you 2.4 guys from GM.....
Competition Calibration
TSB 06-06-04-051
Sep.29, 2006
http://www.alldata.com/tsb/General-M...51/604051.html
TSB 06-06-04-051
Sep.29, 2006
ooooo whats this i see, a gm tune for the 2.4? someone go get this and be our guniea pig i remember when i was getting my tune from westers matt told me that there was alot of room for more programming, and that gm probably had some sort of tune planned for our cars.
just looked at it better.. read the bottem of the page.
"This calibration will be regarded as a customer option and installed at the customer's expense"
Now how much dose it cost??
just phoned the dealer,and they only know the info we know,a service advisor is calling me back,looks to be two part numbers involved but the parts guys have neither of these numbers showing yet in their data base...12615498......12615505....If anyone can find out more info that would be great cause I was going for the hp tune soon so I really want to find out more about this
yea on the page it has.
" *Engine diagnostic calibration, P/N 12615505, is required when using calibration P/N 12615498"
both will need to be done, just not sure what this all is or what it will do for us.
Document ID# 1864895
Subject: Info - Availability of Engine Calibration for Use in High Ambient Temperature and High Load Conditions for Competitive Driving #06-06-04-051 - (09/29/2006)
Models: 2006 Chevrolet Cobalt
2006 Pontiac Solstice (RPO Z0K Only)
with 2.4L Engine (VIN B -- RPO LE5) and 5 Speed Manual Transmission (RPO M86 or MA5)
This is to advise owners who intend to use their 2.4L LE5 engine-equipped vehicle in competitive driving environments under high ambient temperature conditions and/or high loads for extended periods of time of the availability of an engine calibration that will allow the engine to operate at full power under these conditions. This calibration in no way alters the power output of the engine under normal operating conditions. When using this calibration, full synthetic oil (Mobil 1 5W30 or the equivalent) is required.
These calibrations are to be used in Pontiac Solstice and Chevrolet Cobalt SS specific model vehicles only. These calibrations do not apply to all LE5 engines.
Calibration Information
Part Number
Description
12615499
2006 Pontiac Solstice (2.4L) High Temp/Load Calibration
12615498
2006 Chevrolet Cobalt SS (2.4L) High Temp/Load Calibration
12615505*
2006 Chevrolet Cobalt SS (2.4L) High Temp/Load Diagnostic
*Engine diagnostic calibration, P/N 12615505, is required when using calibration P/N 12615498.
Warranty Information
This calibration will be regarded as a customer option and installed at the customer's expense.
Prior to using your vehicle for competitive driving, refer to your vehicle warranty book or your dealership for information on the GM New Vehicle Limited Warranty and how competitive driving may effect your warranty.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Here is the TSB
Š Copyright General Motors Corporation. All Rights Reserved.
Part Number
Description
12615499
12615498
12615505*
Here is the TSB
No performance gain, just prevents performance loss when its really hot outside and when you're running the car hard for long periods of time...bottom line is its a waste of money
Originally Posted by g5mike
too bad,sounds like a lame duck
All it probabily does is turn the fans on quicker for the car to run a bit cooler like it said no real performance gains. I would like to see GM actually wake this car up some. hopefully for both transmissions
Originally Posted by 07G5GT
Sounds Like A Way For Gm To Make Some Money. Its A Good Thing I Work At Gm Dealership. Ill Check It Out And Get Back To You On That.
