Lots of codes - where do we begin?
Old Aug 21, 2010 | 11:09 AM
pjk91's Avatar
Please don't clog this thread with stuff like "how do you supercharge your 2.4"
Background: S/C the 2.4 in 2007? Put about 60k boosted miles on it. Stock pulley, cobra h/e, LFR6A-11 copper plugs @ .034
Symptoms:
- Especially when the a/c is on, idle bounces around upon taking it out of gear (off load) and coasting to a stop
- Misfires most between 40-50mph under light load
- extreme KR >3deg greater than 3800 when more than 50% load
Compression test results were 120 across the board. When not in boost, AFRs are fairly steady between 14.6-14.8. In boost, they seem ok but I don't hit it hard because I can't get rid of the KR.
Almost seems like the car won't hold it's tune. I'll tune it, it will run great for a week and then "learn" something and it slowly deteriorates to its current condition.
Codes:
[ECM] P0101 - Mass Air Flow (MAF) Sensor Performance (Old) (History) (Immature)
[ECM] P0106 - Manifold Absolute Pressure (MAP) System Performance (Old) (History) (Immature)
[ECM] P0121 - TP Sensor Circuit Insufficient Activity (Old) (History) (Immature)
[ECM] P0172 - Fuel Trim System Rich Bank 1 (Old) (History) (Immature)
[ECM] P0300 - Engine Misfire Detected (Old) (Immature)
[ECM] P0420 - Catalyst System Low Efficiency (SES) (Old) (History) (Current) (Immature)
[ECM] P0442 - Evaporative Emission (EVAP) System Small Leak Detected (Old) (History) (Immature)
Old Aug 21, 2010 | 05:39 PM
mmcgee123's Avatar
ur compression seems kinda on the low side
Old Aug 21, 2010 | 07:38 PM
boostedsport's Avatar
those copper plugs are bad **** i heard what are you tuning it with?
i throw p101 and p109 which is crankshaft
Old Aug 21, 2010 | 08:09 PM
mtbrent's Avatar
tuned with HPT
Old Aug 22, 2010 | 12:07 PM
pjk91's Avatar
HPT
To start, how do I find the evap leak?
Old Sep 8, 2010 | 01:45 AM
senior_brown's Avatar
interesting.. i just took my s/c setup off as well and went to stock intake components.
i reused the stock injectors/ harness and put the tb wiring back to stock.
i think my map sensor is dead or almost anyways.
i have re-loaded my stock tune and that is what im running.
upon first start the car idled very well, but within a few moments of me backing it out of the shop i got all these codes
[ECM] P0106 - Manifold Absolute Pressure (MAP) System Performance (Immature)
[ECM] P0107 - Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage (SES) (Pending) (History) (Immature)
[ECM] P0171 - Fuel Trim System Lean Bank 1 (Old) (Current) (Immature)
car cruises well but lean.... 16-17afr, on idle its pegged lean on my LC1 an stumbles and revvs it self up to 3k rpm
Old Sep 8, 2010 | 03:56 AM
my compression was tested at 135 to 140 across all 4
Old Sep 8, 2010 | 09:14 PM
pjk91's Avatar
sounds like the maf needs to be recalibrated, or it's messed up. i still haven't put in a new maf although I think that is the source of most of my problems. That, and a clogged cat as well as a bad o2 sensor.
Old Sep 8, 2010 | 09:19 PM
i picked up a new MAP from my dealer today.. car runs MINT
i have yet to plug in the MAF and take it for a driver... that i will be doing as soon as the laptop is charged so i can log it.
why did you take urs back to stock anyway?
Old Sep 9, 2010 | 08:49 PM
pjk91's Avatar
It's not, it's still s/c
Old Sep 9, 2010 | 10:12 PM
oh i took mine off cuz i was getting a constant missfire on cyl 4 under boost....
Old Sep 18, 2010 | 12:19 PM
pjk91's Avatar
I don't have any of my stock parts, and I need to go back to stock before I sell it.
06MetallicBalt
Jul 20, 2025 08:47 PM
DarrenGC
Dec 24, 2021 01:55 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
SSLOW06
Oct 1, 2015 07:21 PM
