MANGAFLOW exhaust system??
Old Sep 2, 2009 | 09:17 PM
Cobalt08_sport's Avatar
i went to the ZZP site and found the mangaflow ehaust system and notice it came in 2 different sizes...
2.25"
2.5"
and i was wondering which one is best for a stock 2.4L cobalt (not SS)... but then if i got a STAGE 2 turbo by ZZP wat exahust would be best??
Old Sep 2, 2009 | 09:19 PM
chevysssc's Avatar
2.5 is fine
Old Sep 2, 2009 | 09:24 PM
08ShowbaltLS's Avatar
2.5 for both
Old Sep 2, 2009 | 09:28 PM
CinciSS07's Avatar
Your stock exhaust is 2.5 (except for the over axel part, which reduces to 2.5) With a turbo set up you may want to look at a 3 inch exhaust set up though.
Old Sep 2, 2009 | 10:29 PM
Dunkinuts's Avatar
dude you have five threads on exhuast, all basically asking the same thing.
2.5" is best for NA
3" is best for non-NA (turbo, supercharger, nitrous)
Shortly headers are good for high RPM
mid for mid
long for low end power
the muffler is 95% per looks and sound.
stop making a new thread for everything little question the answers are here man. just search really quick.
as for the stock exhaust it is 2.5" except for the over axel part where is is reduced to 2.25". Since you are an 08 like me, you have two cats. So your biggest power gain will be in a new header and downpipe. If you get a high flow cat or no cat you will at some point get a check engine light. it will probably just be that you cat isn't up to the right temp. At least that is what mine is.
Old Sep 3, 2009 | 11:10 PM
2.5" is best for NA
mid for mid
so ur kinda saying just upgrade my downpipe and headers right??
Old Sep 4, 2009 | 09:11 AM
olivecj's Avatar
Yes get header and downpipe then just replace the 2.25 axle section of your exhaust with 2.5 inch piping and throw on a aftermarket muffler then you'll have a full 2.5 inch exhaust for cheap.
Old Sep 4, 2009 | 09:28 AM
Dunkinuts's Avatar
yes, the small section of pipe isn't that bad, the header and downpipe are by far more restrictive.
Old Sep 4, 2009 | 09:43 AM
TurboTechRacing's Avatar
2.5" is what most get.
Old Sep 4, 2009 | 05:43 PM
Mindrot's Avatar
I have the 2.5" and love it
Old Sep 4, 2009 | 05:46 PM
Nato09's Avatar
if you plan on turbocharging your car, then save up and get a 3" system.
Jan 12, 2016 12:01 AM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
nathan112i
Sep 30, 2015 07:12 PM
Sep 27, 2015 08:53 PM
