Max Increased Redline 2.4l?????????
What is the max safe rpm we can push the redline to on stock internals iam thinking 7k
and would increasing completly change the hp/tq curve or just continue to grow as if the stock were 7k?????
so 7000k FTW??
oOooOo and is a 7000k rpm redline attainable on stock injectors??
Iam sure that must have been a pain and would much rather avoid that
well me and tom uped mine to 7100 and its ok but its alittle to high. id say 7k is plenty why i say that is because with our power. the max power peaks at about 6800 and when the rpm gets to 7k the power is already going down. i had it dynoed but they only took it up to 6800 but my redline is about 7100 so if anyone is doing the rpm thing 7k is plenty. and for the speed goes for 2.4s crank that speed limiter up to 145. even though stock tires are only rated for 135 and after 125 the car kinda hangs in 5th gear till i get some more power it should be running great.
ryan.
ryan.
Just curious.... How do you know that the valves floated at 7,250?
FYI, the LE5 in most applications is set to 6,750. The only exception I've seen is that in the Solstice the factory sets it to 7,000. It would be interesting to research and see if there's a difference in the valve springs, which are pretty much the limiting factor in this range.
Thats what I was told by the guy who did the tuning on my car. He has done quite a few 2.4's but since he's in freekin Arizona and can only send me a caned tune and NO ONE around me seems to be able to figure out how to adjust the God damn MAF tables I no longer run it.
Not ranting at you dood I just get pissed over my messed up tune. I tried for months to get it to work right and I never could.
That and I think I read someplace they float at 7250. Can't remember where tho so I guess that doesn't help any.
so you can drift a fwd car?
raising th rev limiter that high on stock injectors is kinda pointless without injectors in. i did it on my car and yes it shifted nice but gm maxes out the stockers at 98idc% at like 6500rpm, so its not even really worth it. get the injectors in..
One of these days you guys will learn about tuning and not guessing....
On stock injectors: 7,100 RPMs, 78% IDC @ 12.8 AFR.
Get the tune right and most of you will have no need for the larger injectors, nor gain a single HP with 'em.
Im game man what can you do? I see your in VA so a drive isn't out of the question for me if you think you can help. Just let me know how much.
Uhhh ya its fairly easy .....instead of criticizing what you dont know ask and I will tell you how, its now secret its just a little harder to do then in a rwd car
wells if thats the case i may just tune it up to 7000k witht the stock ....since your in the know what would my idc and afr be at then ???
hhr guy...is this tune on a hhr? or cobalt? if so i wanna see this....if its on a cobalt. when i ran stock idc% was at 98 at 6500 rpm with just a intake..this is interesting if u can get those numbers low on a cobalt..u have hptuners man?
Same LE5 engine; same E67 ECM; extremely minor differences between the factory tunes.
Hey, the HHR is just a good lookin' Cobalt wagon!!
I've been working w/ HPTuners Pro for some time now.
Vector has mine set at 7k w/ stock injectors. I e-mailed them asking about the IDC% and if it would be wise for bigger injectors and they said no there is no need as they aren't high enough to need them.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Sep 28, 2015 12:51 PM
