Mega Mad LE5 2.4 on the dyno
Old 10-17-2018, 03:46 PM
steelmesh's Avatar
I assembled the engine June-July 2018, first fired mid-August. Dyno pull here, this is with the single 5557 turbocharger not twincharged, yet:
Full build and details here: Twincharged Solstice = Turbocharger + Supercharger
LEA block, LE5 head
Old 10-17-2018, 03:48 PM
Slobodan Milošević
07blackg5's Avatar
Nice numbers. We will have to meet up sometime
Old 10-17-2018, 05:12 PM
Tune mine now
Old 10-18-2018, 09:38 AM
steelmesh's Avatar
Originally Posted by HGT
I would like to hear this in person...
https://www.youtube.com/watch?v=e58sNjn3itU
Here it is at the drag strip you hear the end of my tire cleanup; my best run this day was 13.0xx @ 111.9 mph. It's so quiet, how can it go so fast being so quiet
Old 10-18-2018, 10:35 AM
Slobodan Milošević
07blackg5's Avatar
was that at yesterdays T&T? I almost went haha
Old 10-19-2018, 12:50 PM
steelmesh's Avatar
Planning on T&T Milan Oct 24th, 50F or warming I'll go. My car is pretty much maxed out, so will need to learn how to launch the car and also learn how to 'shift up' instead of shifting down when I'm going 100 mph at the end of the track yes I almost blew up the car last time. I should be into the 12's if I can get a good launch, then be kicked out for the day for being a convertible running 12's.
Old 10-19-2018, 01:20 PM
63 Nova SS's Avatar
With good tires and that kind of power in rwd you could be pushing 12.0 or even high 11's.
Old 10-19-2018, 03:41 PM
steelmesh's Avatar
In addition to drag radials, I will need driving practice. Also consider I was -5 degrees base spark and was hitting 210F IATs at the track last time running a filter directly on the compressor (hot air intake), solely because of packaging challenges, I may need to cut a hole in the hood or get creative.
Old 10-19-2018, 03:53 PM
jdbaugh1's Avatar
210 IAT before or after the intercooler?
Old 10-20-2018, 10:13 AM
chevygirl2006's Avatar
That much power should be in the 11s with a slick.
Old 10-22-2018, 07:47 AM
jdbaugh1's Avatar
Did he show the hp/torque curve from the dyno pull anywhere?
Old 10-22-2018, 09:16 AM
63 Nova SS's Avatar
It would be fun, that's for sure
Old 10-23-2018, 08:43 AM
steelmesh's Avatar
After the intercooler, this should be MAF temp. I was spraying about 70% methanol / water too, so I assume it's maybe 190F at the valve. I will install the LSJ intake for the twincharger, so I'd like to add an IAT in one of the runners [shhhhh, along with 4 nitrous nozzles].
I don't think the barrel style intercooler is very efficient, I'll probably upgrade to a wide core type.
jdbaugh1 (10-23-2018)
Old 10-23-2018, 08:46 AM
steelmesh's Avatar
The detailed build with excessive pictures is here: http://www.kappaperformance.com/foru...c,11551.0.html
Old 10-23-2018, 10:36 AM
Slobodan Milošević
07blackg5's Avatar
yeah, those iat temps are out of control for your setup. They should be nowhere near that.
Old 10-23-2018, 10:59 AM
You’re going to make less or the same power twincharged. Keep it turbo
Old 10-23-2018, 12:06 PM
jdbaugh1's Avatar
I know it would be cost prohibitive but I wonder what the results would be like twin charging a TVS. I'm sure similar but would be interesting to see anyway.
Old 10-23-2018, 12:14 PM
210* on the cold side is insane. Something isnt right there.
Old 10-23-2018, 12:50 PM
tomss's Avatar
Doesn't volvo & Mercedes twin charge their 2.0's? I haven't dug into any of the details. However, I know these are their top HP 4 cylinder's. There must be a reason over just going with a big turbo. My guess is drive-ability.
Old 10-23-2018, 01:38 PM
Slobodan Milošević
07blackg5's Avatar
they use a clutched supercharger and bypass that disengage the blower in the top end
Old 10-25-2018, 07:16 PM
steelmesh's Avatar
Imagine 4 wet spray nozzles behind that lsj intake for the times when it counts =)
Also consider, there is no talking me out of it hehe, I am swapping in an lsj intake and M62 so it's more of an experiment/experience since in-theory it's bolt on. I also considered the worst case is I sell this as a roots style SC kit for a kappa car (Slostice/Sky). This is the first time a kappa car will be M62 swapped; since all the smart ones LS swap.
Old 10-25-2018, 07:19 PM
steelmesh's Avatar
If this works out and I had the dough to throw around I'd do it because it would require cutting and welding the intake snout to work with the Solstice.
Old 10-25-2018, 07:25 PM
steelmesh's Avatar
I did some mild research on it, however it is much more fab work than an lsj M62 swap and I think if I really wanted all-shes-got then a complete bypass tube around the SC with a big turbo behind would blow out the M62 clutched SC.
Old 10-25-2018, 07:42 PM
steelmesh's Avatar
Consider the PT5557 is rated for 495 hp and I am about 525 hp, it's probably making more heat than boost at this point. Also, a guy on youtube (!$&!%$, can't find it) did an empirical test with a heat gun, showed the $250 barrel style intercooler is horribly inefficient compared to a wide core thaitanium air water intercooler. I instrumented water outlet temperature, but I ruled out a bad zzp ignition coil (new) when my car started running bad after that 28 psi cold weather shake down hit on the night before test and tune at the drag strip last Wednesday.
This is what I am looking to ditch the barrel style I am currently running, space is a constraint so it must wait to go in when the SC goes in:
Old 10-27-2018, 11:53 AM
steelmesh's Avatar
It wouldn't fit in a Cobalt but twin M62's would be cheap and 2 liters of flow per rev.. Start out with the large OEM pulleys.
Never even occurred to me, thanks for sharing the idea
Hmm, maybe a retirement project is to Twin-Twincharge a V8 (twin charger for each 4-cylinder bank); assuming we don't run out of high octane gasoline by then:
Josh@ottp
06-04-2014 02:38 PM
thebucky84
04-25-2012 09:53 AM
OttawaMark
09-29-2011 10:25 PM
Psykostevo
02-02-2009 12:36 AM
MVP
12-01-2008 09:40 AM
Quick Reply: Mega Mad LE5 2.4 on the dyno
