Motor Mount gone? HELP
Old Nov 26, 2011 | 06:25 PM
Ownedbyagirl?'s Avatar
So I think the front motor mount is worn out, Every time I hit a bump I hear a clunt.
If I am barly moving 10 KM and I pull the streeing wheel to the left and then to the right as fast as I can and I here a clunk.
What do you guys think it is? My boyfriend thinks its the Motor mount or a Ball joint.
We are getting the inspected at the Chevy Dealership on tuesday....
But what do you guys think?
2006 SS 2.4 AUTO. 115K
Old Nov 26, 2011 | 06:42 PM
Murdered_06's Avatar
Endlinks.....
hhrfreek's Avatar
Could be a number of things from your description...
I would guess initially that it is the sway bar link. Do you have a jack and stands? Jack up the car and try to move the sway bar or hit it with your hand. If you hear or feel any play on one or both sides replace the endlinks. If there is play coming off the sub-frame then its the sway bar mounts.
I had a little noise over bumps and it was the endlinks. I purchased GM links and they were about 65 bucks a piece. I think you can get some Moog links for less at AdvanceAuto, but I thought the Moogs looked like **** so I didn't buy them.
FYI if you shop at AA, check for online coupons. They run coupons all the time. I have never paid full price for anything from them. You can buy in online and drive there and pick it up for 20%+ off anytime if you look up a coupon.
Old Nov 26, 2011 | 06:48 PM
TommyP's Avatar
AWD > FWD
If your motor mounts were going bad you would have front end vibrations, not clunks from going over bumps, that's a suspension issue. As others said, check the endlinks
Old Nov 26, 2011 | 06:50 PM
zrated89's Avatar
sounds like an intermidiate shaft issue to me
Old Nov 26, 2011 | 06:57 PM
Thanks for the in put, He will see it tomorrow.... He said he wil jack it up and take a quick look at the endlinks.
hhrfreek's Avatar
Isn't that specific to F35s? Otherwise I am drawing a blank on intermediate shafts.
NM...Quick google...Your talking steering, not drivetrain?
Old Nov 26, 2011 | 07:14 PM
hhrfreek's Avatar
Both front wheels need to be off the ground to check this. Jack it up from the center-front of the car at the subframe, or one side at a time, which ever. Just make sure there is no load on the suspension.
Old Nov 26, 2011 | 07:18 PM
Verbatim's Avatar
More than likely its the endlinks
it could also be the strut mounts, struts, balljoint, or the swaybar bushings.
Grabbing the endlink and checking for play is a quick easy test but it doesnt always work.
In the past year I have had 2 cars that I have worked on that had bad endlinks that didnt have any play when I wiggled them.
The best way to check the swaybar bushings/endlinks is to unbolt the endlinks from the strut and ziptie them out of the way and test drive it on a nice bumpy road.
If it is the endlinks; get the FE5 MOOG endlinks. They are for the SC/TC balts and are a little shorter than the 2.4 FE3 links. With the shorter links, it will preload the swaybar a little more which will cause the front end to be a feel "tighter".
Im pretty sure that the part number is k750012; but Im not currently at work to verify the # with the parts catalog. Just tell the guy at your advanced-oreilly-zone that your have an 06 supercharged balt
Old Nov 26, 2011 | 07:28 PM
hhrfreek's Avatar
Good call. I like your trouble shooting method.
Old Nov 27, 2011 | 12:29 AM
zrated89's Avatar
correct your thinking intermidiate shaft for the axle. GM's had always have issues with the intermidiate shafts in the columns, and from the description thats always the customers complaint
Old Nov 30, 2011 | 11:03 PM
Update : Apparently the mechanic says there is nothing wrong. He test drove it and checked out the front end and found nothing to be wrong or loose.
Odd thing is my boyfriend pointed out was there were no marks on the dirty black rims we have on (winter steels with winter tires on) He says they didn't even take off the tires.
SO he went in and complained. He got the shop foreman to come in the car for a test drive and he herd it.
He thinks its the strut spring.....***?? lol.
So there going to look at it again tomorrow morning and the foreman wants to see it for him self.
Mechanic has been there for 20 years he says.
If anyone that lives in calgary wants to here it fell free to let me know! HMMM
The guy with the yellow car.... in riverbend... whats your username again!?
Maybe you can help me out!
Old Nov 30, 2011 | 11:08 PM
DiabeticKripple's Avatar
soundjunky is who your looking for. his name is jonathan. shoot him a pm, hes usually on in around an hour.
and your back from the dead haha!
Old Dec 2, 2011 | 05:59 PM
Well the foreman looked at it, He says it might be the sway bar on the right side.
They had 2 machinic look at it and they think nothing is wrong.
So....... Stumped.
Old Dec 4, 2011 | 01:54 AM
This is ownedbyagirl?'s boyfriend.
Did some searches on this Site and found this! I will be going back to the dealership to suggest these.
Service Information
Home Publications Number Search New Bulletins Bulletin Search Feedback Help
2009 Chevrolet Cobalt | Cobalt, G5 (VIN A) Service Manual | Document ID: 2239750
#04-03-08-006D: Steering and Front Suspension Noise Concerns - Clunk, Thump, Rattle, Knocking, Pop, Shudder, Vibration (Diagnosis and Perform Necessary Repairs) - (Feb 24, 2009)
Subject: Steering and Front Suspension Noise Concerns -- Clunk, Thump, Rattle, Knocking, Pop, Shudder, Vibration (Diagnosis and Perform Necessary Repair)
Models: 2005-2009 Chevrolet Cobalt (Including SS)
2006-2009 Chevrolet HHR (Including SS)
2005-2006 Pontiac Pursuit (Canada Only)
2007-2009 Pontiac G5
2003-2007 Saturn ION
This bulletin is being revised to add Condition #3. Please discard Corporate Bulletin Number 04-03-08-006C (Section 03 - Suspension).
This bulletin provides information on seven different steering/front suspension noise conditions.
Condition #1
Some customers may comment on a rattle or knocking noise that is heard in the front of the vehicle while driving at low speeds 8-24 km/h (5-15 mph). This condition may be more noticeable while making a slow turn or on a loose/rough surface.
This condition can be duplicated by the technician using the following procedure:
1. On a rough or loose surface (i.e., gravel parking lot), make a sweeping turn (either direction) at 8-24 km/h (5-15 mph to load the steering column, I-shaft and steering rack/gear mechanisms. The testing on a rough or loose surface will allow the wheels to oscillate slightly and will make the rattle/knocking noise more evident and repeatable.
2. Release the steering wheel while making the turn to take load off of steering components. This should initiate the rattle/shudder noise, which is generated by backlash in the steering assembly as it is in a no-load float condition.
Object Number: 1858410 Size: SH
Click here for detailed picture of above image.
3. Remove the 60 amp EPS fuse (1) in the underhood fuse block.
4. Test the vehicle as in Step 1. Since the EPS motor is no longer powered, only the I-shaft and steering gear/rack will be loaded as you make the turn. If you hear the rattle/knocking noise during the turn, then the noise is being generated by the backlash within the steering column (assist motor gear mechanism).
5. Replace the 60 amp EPS fuse and repeat Steps 1 and 2 to verify that the rattle/knocking noise disappears when turning (loading steering mechanism) and can only be heard when releasing the steering wheel.
Correction #1
If the steering column is identified as the source of the rattle/knocking noise in the above test, replace the steering column.
Important: The noise in the steering column is generated from the metal to plastic gear backlash of the assist motor mechanism and will have a different sound than that from the steering gear. If the customer comments that they still hear a noise, it may be a different sound from either the I-shaft or the steering rack.
If the steering column is not identified as the source of the rattle/knocking in the above test, continue to diagnose the vehicle according to the diagnostics in SI.
Parts Information #1
For part numbers and usage of the column, see Steering Column Kit in Group 06.518 of the appropriate Parts Catalog. Saturn Retailers should refer to the appropriate model year Parts & Illustration Catalog for the vehicle.
Warranty Information #1
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
E7680
Column Assembly, Steering - Replace
Use Published Labor Operation Time
Condition #2 (Chevrolet Cobalt, HHR and Pontiac G5 Only)
Some customers may comment on a clunk or thump noise coming from the front suspension while driving over rough road surfaces. This noise will typically occur when the front suspension is returning to the upward position after a hard downward stroke, such as after driving through a large rut or pothole.
Cause #2
This condition may be caused by the jounce bumper slamming into the upper spring seat because it is not retained in the correct up position. The jounce bumper loses position due to oil being deposited onto its retention fingers. The oil is from the strut leaking.
Correction #2
Inspect the front strut(s) for evidence of oil. The leak may be slight but will still cause the concern. If oil is present, replace the affected strut, jounce bumper and dust boot (shield). Before reassembling the strut assembly, glue the new jounce bumper and new dust boot (shield) to the upper spring seat using the steps listed below. To further confirm this concern, the shield/bumper will easily slide up and down the strut shaft.
Object Number: 2159615 Size: SH
1. Clean the surface area of the upper spring seat using fine sandpaper.
2. Apply a light coat *of 3M™ Automotive Adhesion Promoter, P/N 06396, to the top of the dust boot (shield) on the inside edge and to the top of the bumper. Allow to dry 10 minutes.
Object Number: 2159607 Size: SH
3. Glue the bumper to the inside of the dust boot (shield) as shown. Use *3M™ Duramix™ Super Fast Adhesive, P/N 04747. Allow to cure thoroughly 5-10 minutes at room temperature.
4. Apply a light coat of *3M™ Automotive Adhesion Promoter, P/N 06396, to the top of the dust boot (shield) and to the upper spring seat surface. Allow to dry 10 minutes.
Object Number: 2159612 Size: SH
5. Glue the dust boot (shield) to the upper spring seat as shown using the above recommended adhesive. Allow to cure thoroughly.
*We believe this source and their products to be reliable. There may be additional manufacturers of such products. General Motors does not endorse, indicate any preference for or assume any responsibility for the products from this firm or for any such items which may be available from other sources.
Parts Information #2
Part Number
Description
Qty
Material Allowance
21992520
hield, Frt Suspension Strut
22712118
Bumper, Frt Suspension Strut
04747
$22.00
06396
$4.00
For part numbers and usage of the strut, see Strut Kit in Group 07.345 of the appropriate Parts Catalog.
Warranty Information #2
Labor Operation
Description
Labor Time
E9478*
Replace Front Strut and Secure Bumper and Shield to Spring Seat
1.5 hrs
AddTo Perform Repair on Other Side
1.3 hrs
AddFor alignment times, refer to operation E2020 and add the applicable times to the regular hours.
* This is a unique labor operation for bulletin use only. The number will not be published in the Labor Time Guide.
Condition #3
Some customers may comment on a clunk/pop type noise coming from the front of the vehicle when driving over rough road surfaces.
Cause #3
This noise may be caused by the stabilizer shaft link ball stud becoming contaminated from moisture.
Correction #3
Inspect the front stabilizer shaft links for damage. To isolate the noise, the link can be also be disconnected from the stabilizer shaft. If the link appears damaged or if the noise goes away when disconnected, replace the link with the revised part.
Parts Information #3
Part Number
Description
Usage
Qty
20784686
Link Asm., Front Stabilizer Shaft (300 mm Shaft)
2006-2009 HHR (FE1, FE3)
2005-2009 Cobalt (FE1, FE3)
2005-2006 Pursuit (FE1, FE3)
2007-2009 G5 (FE1, FE3)
2003-2007 ION (FE1, FE2, FE3)
Link Asm., Front Stabilizer Shaft (250 mm Shaft w/Washer)
2008-2009 HHR (FE5)
2005-2009 Cobalt (FE5)
2007-2009 G5 (FE5)
Link Asm., Front Stabilizer Shaft (250 mm Shaft)
2005-2006 Pursuit (FE5)
2007-2009 G5 (FE5)
Warranty Information #3
Labor Operation
Description
Labor Time
E2147
Stabilizer Shaft Link Replacement (Both Sides)
Condition #4
Some customers may comment on a clunk type noise coming from the front of the vehicle during a turning maneuver. This condition can also be felt through the steering wheel when the vehicle is stationary and the wheel is rotated from steering stop to steering stop. Typically, the clunk noise will be heard once for every 90° of steering wheel rotation in either direction. This clunk noise may also be noticed during low speed acceleration or deceleration, typically in light turns of the steering wheel.
The following are characteristics of this noise:
• This noise is very random.
• This noise is independent of the steering wheel angle and independent of the bumpiness of the road.
• This noise is a low frequency dull one and can be felt in your feet.
• This noise can normally be heard from the driver seat.
• This noise can be felt upon touching the steering gear from outside of the vehicle.
Note: You might also notice a slight scrub-type noise when turning the wheel back and forth. This type of noise is considered normal and repairs will not eliminate it.
Cause #4
This condition may be caused by inadequate lubrication of the steering intermediate shaft.
Correction #4
Important: DO NOT replace the steering gear or steering column assembly.
Replace the intermediate shaft.
Important: If the vehicle has already had a steering intermediate shaft replaced for a similar noise concern that the dealer duplicated, determine from the customer if the noise went away for a period of time and came back, or if the service shaft made no change. If the noise was gone for a period of time and came back, have the dealer replace the shaft again to verify we do not have a defective service shaft.
If this does not eliminate the noise, continue to diagnose the vehicle according to the diagnostics in SI.
Parts Information #4
Part Number
Description
15800140
Shaft, Intermediate Steering (Cobalt/G5/Pursuit)
15799676
Shaft, Intermediate Steering (ION)
22730246
Shaft, Intermediate Steering (HHR)
Warranty Information #4
Labor Operation
Description
Labor Time
E7700
Shaft, Steering Intermediate - Replace
Condition #5
Some customers may comment on a rattle/clunk type noise coming from the steering column when driving over bumps.
Correction #5
The following steps have been found to be very effective in removing this condition.
Object Number: 2003905 Size: SH
1. Check for the possibility of the PCM and the TCM rattling/clunking together. If there is contact between these two modules, insulate the modules from each other using a small piece of foam.
Object Number: 2003906 Size: SH
2. Check that the retaining clip on the engine coolant surge tank is fully seated. If not, push down to seat.
Rattles/clunks in this area of the engine compartment may be heard as coming from the steering column while driving.
Warranty Information #5
Labor Operation
Description
Labor Time
E9458*
Repair to Correct Rattle/Clunk Noise in Front of Vehicle
0.2 hr
* This is a unique labor operation number for bulletin use only. The number will not be published in the Labor Time Guide.
Condition #6 (FE1 Suspension Only)
Some customers may comment on a clunk, thump or rattle noise coming from the front suspension while driving over rough road conditions or when braking.
Cause #6
Object Number: 2003907 Size: SH
This condition may be caused by the lower control arm rubber bushing (rear) coming out of its steel sleeve (1). This will cause the lower control arm to make hard contact (2) with the body structure. This condition may be more prevalent in regions that use road salt during the winter months.
Correction #6
If the rubber bushing has moved out of the steel sleeve, replace the lower control arm bushing. Do not replace the bushing if it is still centered in the steel sleeve.
If this does not eliminate the noise, continue to diagnose using chassis ears to identify the source of the noise.
Parts Information #6
Part Number
Description
25984679
Bushing, Front Lower Control Arm (Cobalt/G5/HHR/Pursuit)
22688205
Bushing, Front Lower Control Arm (ION)
Warranty Information #6
Labor Operation
Description
Labor Time
E3550
Bushings ad/or Shaft, Front Control Arm Lower (Right) - Replace
E3551
Bushings ad/or Shaft, Front Control Arm Lower (Left) - Replace
E3557
Bushings ad/or Shaft, Front Control Arm Lower (Both) - Replace
Condition #7 (Saturn ION Only)
Some customers may comment on a squeak, rattle, pop, or clunk noise coming from the front of the vehicle during suspension movement.
Cause #7
This condition may be caused by the interface between the front stabilizer shaft, the front stabilizer shaft insulators (bushings) and the front stabilizer shaft mounting clamp.
Correction #7
Replace the front stabilizer shaft insulators (bushings), if necessary, using the following procedure.
1. Verify the customer comment. Use Chassis Ear (SA9217NE or J39570) or a similar tool to determine the source of the noise. Refer to Noise Diagnosis - Front Suspension in SI.
2. If the noise is coming from either the front stabilizer shaft insulators (bushings) or the clamps:
Important: Check the Service Parts Identification label in the rear compartment (trunk) to determine the vehicle's suspension system type, then obtain the correct insulators (bushings) corresponding to that suspension system type.
• On vehicles built after VIN breakpoint 4Z125195, replace both front stabilizer shaft insulators (bushings). Refer to the Stabilizer Shaft Insulator Replacement procedure in SI.
• On vehicles built up to and including VIN 4Z125195, replace the front stabilizer shaft insulators (bushings) and clamps. Refer to the Stabilizer Shaft Insulator Replacement procedure in SI.
3. Verify the repair by repeating Step 1.
Parts Information #7
Part Number
Description
Qty
15820162
Insulator, Front Stabilizer Shaft (2007 FE1 Suspension)
Insulator, Front Stabilizer Shaft (2007 FE2 Suspension)
Insulator, Front Stabilizer Shaft (2003-2007 FE3 Suspension)
Clamp, Front Stabilizer Shaft
Warranty Information #7
Labor Operation
Description
Labor Time
E2180
Insulator and/or Bracket, Front Stabilizer Shaft - Replace
Condition #8
Some customers may comment on a whine/hum noise from the steering column while making right hand turns at 5-15 mph (8-24 km/h). A slight whine/hum noise is considered to be normal for EPS so it will be helpful to compare to another like vehicle. If the vehicle exhibits excessive feedback/noise when compared to another vehicle, follow the correction procedure below.
Correction #8
Important: DO NOT replace the steering column.
Pull the 60 amp steering fuse (1) in the underhood fuse block. If this eliminates the whine/hum concern, contact the Technical Assistance Center for further information in order to repair the vehicle. If this does not eliminate the noise, continue to diagnose the vehicle according to the diagnostics in SI.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Š 2009 General Motors. All rights reserved
Old Dec 4, 2011 | 11:56 AM
Verbatim's Avatar
Have you tried disconnecting the endlinks and taking it for a test drive?
If you don't know what is wrong with it, you need to start eliminating what's not wrong with it...
Old Dec 9, 2011 | 10:26 PM
boyfriend noticed grease nipples.... should he put grease in it?
Old Dec 10, 2011 | 12:28 AM
hhrfreek's Avatar
Please take the time to do this...it could save you a lot of time...
I asked a mechanic if there was anything that was worn in my girlfriends car since I heard a clunk over bumps when I brought it in for new tires and an alignment...and he said he noticed nothing...I changed the oil that morning before I brought it in and could feel the play in the endlinks...I knew what the problem was since this is the second set I put in her car(Moog...I thought you had good parts)...and he couldn't diagnose the issue, which was obvious to me and resolved the following day when the parts I already ordered came in.
ThoR294
Oct 4, 2015 08:44 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Stuff
Oct 1, 2015 05:47 PM
n20saturn
Sep 30, 2015 12:26 AM
