... My Build... Muhahahahahha
#126
haha i was waiting on the other vidz to be sent to me .. i'll post them up tomorrow .. i have one of me driivng around a bit
and jer my pod seems to fit good.. send me some pics so i can see what you mean
#128
more vidz
http://www.youtube.com/watch?v=Tu5MP...e=channel_page
http://www.youtube.com/watch?v=VoVMS...eature=channel
http://www.youtube.com/watch?v=UGrcu...eature=channel
word yes there are 3 people in the car aside form me and yes i did a ricer flyby .. i was hoping to pull the guy to race lol
i apologize for the sound on the youtube ones.. they're cell phone vidz cuz my camera was dieing.. I have one more from my camera but i need bateries so i can uploadit lol i'll get some tests of the launch control when i hit the track lol or on a warm day so i have a chance at hoooking lol.. the rt 615's are great tires but they hook MUCH better when warm lol
#130
1. yea he can adjust my speedo but i didn't think about that when purchasing the tires lol i'll keep it in mind for next time lol
2. 3.2 pulley on the dyno and still on the car ( i'm going to need a clutch before i go any crazier )
3. yup they're rt-615s they're amazing when they're warm.. when they're cold.. well .. not so much lol .. they still hold the road pretty well but i can spin them pretty easy..
#131
I am seriously considering buying them for my Auto-X tires. Right now I am running the stock lops from the RL.
I also need to replace two Goodyear Eagle F1s on my "Fo Sho" wheels. I am thinking about getting some rt-615s for those also since they are not that expensive.
#132
What other tires have you used? How do they compare?
#134
i luffz it .. i want to get a 3" catback and hit a dyno jet so i can dyno on what most other people dyno on lol .. yea i'll probably get higher numbers but thats ok ... i got the realistic numbers down.. lets go for inflated numbers like most other people...
either that or i'll hit the mustang dyno paul used for a while and put down 440 whp on
but i need some more mods before i spend the money on it .. i'm thinking 3" catback and some cam timing changes via tuning .. from some discussion with some peoples that would be the best for me as i could get a mini cam since there will not be a great grind / easy grind for my car due to how it delivers power.. having a cam deliver power from 2500 - 7500 is going to be hard to come by ... but with the stock cams and some finagling it might be able to be worked out lol
i'm hoping with those extras I can put up a 275 whp number .. hell with my setup right now on a dyno jet i might be able to pull off close to that... a 200 rpm increase got me 5 whp so even if the 400 rpm increase i did only gives me 5 more peak i'd be at 257 on the same dyno... the 3" catback over the 2.25 i'm running now should definitely help out too then the cam tuning will more be to extend the power band lower so i get more power at 2-3 k since right now power starts in at like 3500 i start getting 1 psi at like 3000 so a little grunt down low would help out a bit we'll see though.. my torque will probably only be like 220 wtrq after all taht though lol but oh wells
#135
Well it seems to be coming along nicely, the problem is we are never satisfied, it's all about more, more, more, lol....
I think 275 is realistic with the mods your describing. I'm curious as to why the torque numbers are not higher on this setup. I just figured the procharger would put up some nice torque numbers, especially on the 2.4L. It seems like it pulls pretty hard from the vids. Hope it keeps getting better for you.
I don't think i am going to make gmnationals, i am kinda bummed i was looking forward to that show, but i have something going on and don't think i will be able to make it...
I'm getting mine dialed in finally, i've had alot of issues with lean trims and my idle was all screwwyy. But i think vince has that taken care of, i'm planning on having the rear section of my exhaust done this week, 2.75". Then i'm going to bump the boost up to 9lb and see how she feels.... I need a video cam so i can make some vids too...
#136
well the "issue" with prochargers is they hold peak torque longer then most other setups.. so that causes them to create higher HP numbers then you would think.. if you look at my dyno chart.. i loose like 8 wtrq from peak to redline ... obviously thats going to produce hp lol
eventually if i rev it up high enough ... i'll produce a "normal" curve.. but untill now.. i'm happy with getting a linear HP curve that builds till redline hehe.. wait a minus how much boost are you running now? like 7 lbs?
but und
it's soooo hard for me not to drop a pulley size.. lol ... but unfortunately i'll probably need a clutch before then .. my clutch started slipping with this pulley for a bit.. but then vince set me up with NLS which has been alot better on my clutch.. I can do WOT shifts now and the only issue i have is massive spinnage lol
we're thinking that with a massaged head some cam tweakage and a 3" exhaust I should be able to hit 300 whp on this pulley but unfortunately a ported head isn't cheap at all lol
#137
dude.. i dunno how far NJ is to you ... ? if it's not SUPER far you should goto the GONE meet in july i'll be there .. paul will probably be there as well as a few other guys from the area...
but und
but und
I'm running 7lb right now, i really want to go up, but it's such a pain in the ass to change my wastegate spring cause of where it's at and how the exhaust is ran, so i'm draggin my feet about doing it. I thought about gettin a boost controller but i know what that will end up like, MOTOR IN PIECES, lol... I'm not going to dyno until after show season, just in case it let's go, i'll have all next winter to build it back up again... lol... I do plan on pushing it though, i'm not sure what the stock engine 2.2l whp record is but i'm going for it, lol...
#138
Ported Head= Pure happiness= Empty wallet, lol.... You got a link to the meet in jersey? Only place i've been in NJ was right outside of NYC and it took like 5.5 hrs to get there...
well you could get a digital boost controller which has over boost protection or something.. they're pricey but idk man.. i'd never want to be changing wastegate springs everytime i want more boost lol
but yea like you said ported head would be pure seckz but like you said empty wallet .. and right now .. fixing my suspension and rear brakes are more important .. which will probably come in the form of coilovers and rear disk conversion.. which you might want to look into that conversion man... 450 bux on GB now .. with SS lines .. brembo blank rotors and such we have the same plan.. I want to push it as far as it can go.. i'm hoping i can hit 350 whp on stock motor .. i think it's possible
#139
I'll look into the meet...
As for the boost controller, i was just looking at the hallmanpro at extremepsi, it's only like $85.00 and it seems like the safest mbc on the market, i'm not as worried about the boost controller failing as i am worried about me being tempted to twist the happy knob just one more click lol....
Who has the GB on the brakes? Bigger, better brakes are one of the things on top of my list, but i really want to stay with my 4 lug pattern and most places don't offer the rear conversion for that...
Damn, that meet is like 5.5 hrs away, lol... IDK about that, i'll keep it on my list, i've been wanting to hit some meets and car shows outside of my normal 150 mile radius, lol...
#140
haha just put the mr clicky in a shitty spot so it's a bitch ... to turn? haha but seriously ... just gotta have self control lol it's hard i know lol ...
https://www.cobaltss.net/forums/deleted-threads-89/well-i-know-have-rear-discs-173155/
theres a link about the rear brake setup
#141
ok so i'm going to have to do a blower oil change soon so i figure hmm lets fix some things, i'll be clocking the blower so i don't have the U bend anymore cleaning the air filter
and oh yea... prolly this
LAWLZ 300 whp i'm coming for joo bish lol
also i'm looking to pick up a set of coilovers since my suspension is pretty fucked and the rear disk swap since my rear brakes are fucked as well lol
and i'm hoping to hit the track the 21st or 28th well see how it goes.. well theres my update for a bit till i get things done
#142
Dude, I'd just stick with the dyno you have been using to stay consistent! If it matters that much, wait til you are totally done with the build and are happy with your power level, THEN hit a dynojet and show everyone up haha. How's the clutch doin lately btw?!
#143
since i got NLS clutch is great as when i WOT now it's not trying to go into gear at 7k lol
i wont be happy till i hit 350 ok thats a lie i'm happy now .. however it's just fun to have more powah lol when i made 252 i was really happy lol now i'm probably closer to 260 or so since i bumped my redline up 400 more rpms and i'm seeing about 1.5 more lbs of boost i'm hitting closer to 9 now
#144
well there will be more updates for this coming soon
i hit the track last night and determined i really need a new suspension lol
2.442 60' 14.31 et and 102.02 trap
i should be easily in the 13's but i fail as a driver and having a **** load of squat from blown out shocks/ struts doesn't help lol
but soon there should be some new developments.. hopefully the suspension will get fixed as well as some other new parts be put on
