My experience installing zzp stage 3 turbo kit.
#78
Considering how sweet the ecotec platform is in general, there is 10+ years of aftermarket parts, 2.4 has alot of room to grow. can't wait til i save $$ the for my bottom end. only $2500 to go! well maybe a few hundred more, planning on renting a truck and driving to Wyoming Michigan.
I know macgee before he left css.net was doing mid 400's WHP on a LE5, which is stupid quick for a street car. I allready want to get the quaife F23 LSD at my power levels, cant immagine what his 2.4 would of been like LOL.
to add something useful to the expierience of the ZZP kit, i solved my P0128 coolant code, was a thermostat (seems to be the case 99% of the time)
so:
P0010 - Intake cam position / actuator -replaced intake and exhaust solenoids $80 for both
P0121 - Throttle Body position - Cleaned corrosion on circuit/checked with voltometer + cleaned TB
P0128 - Coolant ECT engine not warming up qucikly - Replaced thermostat $70, did coolant as well.
P0171 - Came on for first time last night - bank 1 too lean. i was neutral coasting on highway when it triggered, probably nothing, cleared it, hasn't came back on yet.
Not sure if these are because of the kit, they are all normal reported LE5 Maintenace issues on stock LE5's as well
Seized/old thermostat pics - notice the black rubber seal, causing the thermostat to jam
#80
Just as a reference for that whole spend less get more.
https://www.cobaltss.net/forums/dyno...2012-a-272372/
There are 13 LSJ and 10 LNF 2.0 motors making over 400 but only ONE 2.4 making it there with just a turbo kit.
#81
Displacement particularly in our engines isnt everything. The head and cam work is where people are seeing the biggest gains.
#82
What I meant was its not the deciding factor. A turbo swap on a 2.0 LSJ makes well over 400 with a turbo swap. The 2.4 just isnt doing that with the same mods.
A similar modded 2.4 vs 2.0 made 324whp at 14 psi, the LSJ made 338 at 15 psi. Both on E. Very close considering dyno numbers can be off a considerable amount; if the displacement was everything there would be very different results.
All I am saying is the the 2.4 is a great motor, but the LSJ is superior and doing it with less displacement.
#83
if you rake a 2.4 and a lsj put the same snail on them the 2.4 will out hp and tq the 2.0 on
but for the 2.4 to compete you need to fix the weak link
cubic inches matter on any platform
#84
well I got a question to get this thread back on track:
how did you guys hook up your boost gauges? I have the little nylon line with the brass fittings on the end but IDK how I can hook that up to the manifold. Thanks
#85
I tapped the line coming from my throttle body that was originally the EVAP purge line but removed that and isntalled the BRFPS, it now became my pressure line to increase my fuel pressure using the ZZP kit. I then ran a "T" into that line for the gauge. It really doesnt matter where you tap to get your gauge reading as long as its between the throttle body and the head (intake manifold, post TB).
#86
check to make sure all your spark muiltiplers are zero-ed out, theres a million on the e67 pcm so it could be something weird like that. also with the PE make cure COT and those multipliers are all zero as well. maybe check your open loop eq graph too just to be thorough
#93
the connectors on the side of the module are for voltage inputs, you create equations for what the voltages mean then give them the proper names in HPT.
for example the aem wideband has a 0-5v output based on afr/lambda, so you add the output wire from the aem to the hpt pro module then add the user configured PID to the scanner.
edit: I hope you haven't been tuning your MAF high without this.....
#94
do you have hpt pro?
#95
i have hpt standard. I know there are 5 volt inputs on the HPT pro, but use my wideband in the car and the wideband on the dyno to tune. I am running the LC-1 controller and G3 gauge from innovate. Its good stuff. You can tune without HPT pro, people do it all the time. I figured he was using the inputs on HPT but wasnt sure if some of that was form the 2.4 liter inputs.
I'd definitely suggest that you use your ac press sensor to log afr so you can get afr error. There's a how-to on it, but essentially all you have to do is disconnect the ac pressure signal wire and connect that to your wideband voltage output, then make a custom PID using that to determine afr.
Tuning WOT any other way then AFR error on a maf only setup is just unnecessary risk
edit: found it https://www.cobaltss.net/forums/how-...ctures-275518/
#98
Its 289 bucks to upgrade but I think it will be worth it, I have to ship my box back to them. I have since learned that you can log the car without a laptop! That is going to be awesome. I can log everyday and if the car hiccups I can go find out why. So far the car is so dialed in its nice to have my daily driver back running 24 psi daily (about 430whp) is just so much fun. When I start running it at 27psi I will really want the HPT pro to log daily for those just in case situations.
#99
The fuel pressure is a standard PID in the e67 ecm and you should be able to log that without the pro version.
Like he said above I have the pro and the AFR, EGT are input to the EIO of the HP Tuner to log them.
I'll look for that stuff after work and see.
The tune is posted at HPT if you'd be so kind to have a little glance at it sometime.
What causes this TQ Mang. I need help.
Thanks
Thanks
