need help on a A/F gauge
Old Sep 28, 2008 | 07:40 PM
rockstar014's Avatar
hey i looked on a how to thread on how to hook up a A/F ratio gauge but i need to find a purple with a while stripe wire but i could not see one anyone want to help me the how to said it was one of the wire in the ecu
Old Sep 28, 2008 | 07:42 PM
Dayta's Avatar
same boat as me right now
Old Sep 28, 2008 | 07:48 PM
mrsilent13's Avatar
are you doing a narrow band for just a light show or a wide band that actually works
Old Sep 28, 2008 | 08:27 PM
Doc's Avatar
Doc
great question....
Old Sep 29, 2008 | 12:59 AM
a narrow band is a narrow band for right now
Old Sep 29, 2008 | 11:58 AM
mrsilent13's Avatar
well i wish i could help but i could have helped you in building a wideband.....but its all good. i really dont see a point in a narrowband....it does nothing for me
Old Sep 29, 2008 | 12:04 PM
LamboW9's Avatar
h/o i'll find the thread i used
https://www.cobaltss.net/forums/show...row+band+a%2Ff here...last page
Old Sep 29, 2008 | 12:09 PM
glen229's Avatar
you hvae to wire it into the purplish wire coming out of the four wire oxygen sensor on the header (first o2 sensor)
Old Sep 29, 2008 | 12:11 PM
LamboW9's Avatar
no you don't....they both report readings to the pcm....and the one in the header is before the cat so which do you want?..a reading before the cat or after?....after
Old Sep 29, 2008 | 12:36 PM
well my car has no purple wire with a white stripe all i have is purple ones
Old Sep 29, 2008 | 12:38 PM
LamboW9's Avatar
did you go to that thread i posted here?...you can get a signal wire off of your rear O2 sensor....the black wire will give you signal
Old Sep 29, 2008 | 12:44 PM
yea i was just looking at that ok i will try that one thanks a lot
u get a good signal lambo??
Last edited by rockstar014; Sep 29, 2008 at 12:44 PM. Reason: Automerged Doublepost
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
