Need some help! weird popping noise and gasoline smell
Old May 1, 2012 | 02:17 AM
Twoozofjuice's Avatar
Soo I put on a sc kit and was pretty much done. Just wrote the tune in and was filling the heat exchanger with coolant. Well I first filled the heat exchanger then when it was done bubbling I turned the key on the on position so I could write in the tune. When I finished writing it in I was going to go check the heat exchanger hose to see if it was still bubbling and some weird noise somewhat like a bunch of air escaping but for a split second happened and now I smell some gasoline. Anyone know what I needa do or did wrong? I still havent filled the radiator with coolant
Old May 1, 2012 | 04:47 PM
Tcobalt421's Avatar
oh boy, hpe you findout the prblem and its nothing major
Old May 1, 2012 | 04:54 PM
Chevycobaltss3's Avatar
Sounds like a fuel leak, or vacuum leak Bro.
Old May 1, 2012 | 06:07 PM
I think it was both lol.
In my desperation to get the damn thing running already I forgot to plug the line thats on the throttle body back in.(had taken it off when changing the oil because it was in the way of my hand) Also I broke a bolt that holds the fuel rail down and didnt notice until after I was inspecting it this morning. Thats where the spilled gasoline seemed to be. In the 4th injector or the one thats closest to the drivers side. Now I just needa get a left handed drill bit to get the damn broken bolt out because I couldnt do it earlier today. Sometimes I hate having to go to school. Anyways hoping when I get home today I will be able to get the bolt out, replace it and get the car running finally.
Old May 1, 2012 | 06:12 PM
Tune time.
Old May 1, 2012 | 06:17 PM
Adventure Time!
No but seriously lol going to get it running tonight and get you some logs with the correct configuration this time!
Old May 1, 2012 | 07:38 PM
Alright bro.. Sweet!
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
SlowSaturn
Sep 28, 2015 11:03 AM
