O2 Sensor
Old May 31, 2009 | 12:35 AM
mmcgee123's Avatar
get a tune ull pass emissons for newer cars they just pull up codes id kno we do emissions testing at my work and for the pullin the batter cable to clear the codes sry not being a dick but thats reatarted is still stores the old codes in history so then they put it thru a duty cycle which will thro the original codes it threw b4
Old Jun 1, 2009 | 12:22 AM
Hockeyman's Avatar
Originally Posted by kevinj4891
wrong sir.. sorry, but i tried both...first the ARK.. for our 2.4's, there is not enough clearance. you put the spacer on and the O2 sensor wont go on...not enough space.it gets wedged between the spacer and frame rail.
as for the Spark plug non fouler. i was only able to get 1 out of the 2 on for the same reason. thought 1 would do it, WRONG. you still get a light. i bought a scanner and i clear the code about every 2 - 3 days. nothing to do about it then to HP tune it out
two antifoulers fit on mine just fine. If they don't, just go to a muffler shop and have them weld you in a new bung that is lower, problem solved. I am not wrong
Old Jun 1, 2009 | 12:57 AM
elecblue06's Avatar
in NY... you're allowed to have one unready sensor.. all they do is plug it into tech 2 and check for codes.. if you do a battery reset you need about 500 miles or a certain amount of starts before the cat cel will come up .. before that point it'll come up as an unready sensor ..
Old Jun 1, 2009 | 09:36 AM
Red07SSNA's Avatar
Shop around...there is an O2 sensor extender that is "L" shaped so you can reposition the O2 sensor along the exhaust. I can't remember the manufacturer's name but it was sold on ebay. Those that had problems with the 2-antifoulers found this "L" shaped one worked better.
Old Jun 1, 2009 | 03:14 PM
mmcgee123's Avatar
yea its fine to have a unready sensor that's what I have on mine but I was say the battery thing won't work we see it alot at my work also the check engine light bulb pulled never works ha
Old Jul 20, 2010 | 10:23 PM
neumannl001's Avatar
Good conversation! so the smart way is tune and turn off code if I have the money to do it in order to pass smog. Is that right?
Old Jul 28, 2010 | 05:46 PM
kevinj4891's Avatar
ok, my experience....
i had V2 header and vibrant downpipe w/high flow cat. bought a $20 L-shape adapter off e-bay and fixed the p0420 code, THEN another code popped up. the issue was now with the first O2 sensor. some aftermarket header's don't put the sensor in the right spot and it throws a code. i bought a new front O2 sensor and tried to fix it, didn't work. i took off the exhaust, brooke the front one in the process, and sold it. put my stock exhaust on with the original O2 sensor and everything was peachy.
the 2nd code only came up after i fixed the p0420 issue... you may have more than 1 code, so the second O2 sensor fix may NOT solve your problem
my 2 cents
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
jmelton327
Sep 26, 2015 10:04 PM
Knightwolf
Sep 12, 2015 11:02 AM
