The official FullThrottle build thread
Old Apr 2, 2007 | 07:41 AM
MVP's Avatar
MVP
I put this in the 2.4 performance section because eventhough I have a redline my short block is a LE5 (just with upgraded components.) Its actually a hybrid engine. its a LE5 short block with a LSJ head. for now im going to be running the lsj supercharger. However, I have a full turbo conversion in the works. my engine isnt in my possession yet but it should be here this friday. the link is from the redline forums so change the address accordingly. change the "Y" to an "I" just thought id share this with you guyshttp://www.redlyneforums.com/forums/...e+build+thread
Old Apr 2, 2007 | 09:26 AM
celicacobalt's Avatar
pics???
Old Apr 2, 2007 | 09:34 AM
shabodah's Avatar
FT= Teh Gheyness. j/k
Old Apr 2, 2007 | 09:44 AM
06blackg85ss's Avatar
LOL... ****'s slow..... (j/k man hahaha)
can't wait to see numbers from this build
Old Apr 3, 2007 | 12:46 AM
MVP's Avatar
MVP
Originally Posted by celicacobalt
pics???
Did I forget the link or something? just messing with you man. the pics are in the link.
Old Apr 3, 2007 | 11:22 AM
YellowG5's Avatar
I get a weird exotic picture site when I click the link...is the link right? Nevermind, fixed it...change the Y to an I in the word Redline, you spelled it Redlyne
Old Apr 3, 2007 | 07:02 PM
elmstreet's Avatar
well he had to put a Y instead of an I or else it would have blocked it
Old Apr 3, 2007 | 10:45 PM
YellowG5's Avatar
may I ask Why?
Old Apr 4, 2007 | 12:38 AM
MVP's Avatar
MVP
Originally Posted by YellowG5
may I ask Why?
its all buisness this forums owner and the redline forums owner have competing forums.
Old Dec 1, 2007 | 10:02 PM
MVP's Avatar
MVP
WOOO HOOOO THE BEAST IS ALIVE ONCE AGAIN. Thanks to Philly938 and a little bit of patience. the fuse block under the hood was a bit loose causing one of the relays to not get a good connection. thats the short end of the story. shes running pretty rough but nontheless she runs
Old Dec 1, 2007 | 11:24 PM
REDFOCZ's Avatar
I demand pics and videos of the 2.4 superchared IRL. Dynos and 1/4 miles times work aswell
Old Dec 2, 2007 | 01:05 AM
awesome man
Old Dec 2, 2007 | 01:09 AM
stryder's Avatar
now get that bitch tuned
Old Dec 2, 2007 | 01:17 PM
MVP's Avatar
MVP
LOL Yeah Gotta get her to stay running first. then ill be spending time at mike's (LSJFan on here) house and well start road tuning. then its off to the dyno to tune even more.
Old Dec 2, 2007 | 02:17 PM
stryder's Avatar
YAY! this should be fun
Old Dec 2, 2007 | 02:34 PM
REDFOCZ's Avatar
Are you still useing the P12ECM out of your RL or did you convert to the E67?
Old Dec 2, 2007 | 04:19 PM
Viper33884's Avatar
Nice, can't wait to see the final outcome.
Old Dec 2, 2007 | 09:10 PM
IonNinja's Avatar
I'd imagine he'd need the LSJ ECU since he doesn't have VVT...
whys it running crappy though?
Old Dec 2, 2007 | 09:23 PM
REDFOCZ's Avatar
the Ve is most likly out of whack which is going to cause bad Idle. Also you have to tell the ECM about the increase in displacement.
Old Dec 2, 2007 | 09:42 PM
Johnny1Nut's Avatar
What, this thread started in april and you still don't have it running?????
That is almost as bad as that other guys project.
Old Dec 2, 2007 | 10:36 PM
MVP's Avatar
MVP
I'm in the military. nuff said.
I'm about 2 Whole steps ahead of ya on that one man. I'm 99.9% sure it is not the VE table.
Old Dec 3, 2007 | 12:19 AM
IonNinja's Avatar
oh I thought he meant it wasnt running right as in mechanically...if it still needs to be tuned then nevermind.
lotta people doing cool stuff with 2.4's lately, I want one.
Old Dec 3, 2007 | 01:06 AM
REDFOCZ's Avatar
Ah..... I see, I bow apon the knowledge of ye old wise one
Old Dec 4, 2007 | 03:21 AM
MVP's Avatar
MVP
LONG STORY SHORT as you guys know, my set up is a 2.4 LE5 short block with a LSJ head and intake and supercharger. a F35 trans all the sensors and ECM/BCM from a LSJ (ion REDLINE) I have the engine all buttoned up in the car and i fired it up the only problem is that I have to fether the throttle to keep it running. i checked the cam sensor the crank sensor both of which are good and installed correctly. im still theowing the P0017 DTC Which is Crankshaft/camshaft position corellation sensor B. sensor B references the camshaft sensor which is installed correctly. the cams are installed correctly the crank shaft pulley/balancer is installed correctly. my next big question is I need to find out if the reluctor rings are the same on a 2.0l and 2.4l. I know that they are both 58x with a 12deg reference gap but is the gap in the same place?
06MetallicBalt
Jul 20, 2025 08:47 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
riceburner
Oct 2, 2015 05:47 PM
