Overdrive??
Old May 17, 2009 | 12:16 AM
jhop16's Avatar
Overdrive??
Do these 2.4L sports have an Overdrive?? if so, how do u take it off ... or is that only what automatic trucks have lol
Old May 17, 2009 | 12:27 AM
08G5GT2.4L's Avatar
Most auto transmissions have it, it just changes the input on the planetary to give a overdrive ratio. There is no taking it off. Why do you ask?
Old May 17, 2009 | 04:50 AM
HunterKiller89's Avatar
you should research what an overdrive gear is...because there is absolutely no reason to want to remove it
Old May 17, 2009 | 04:53 AM
originaladrian's Avatar
why the heck would you want to make yourself slower....
Old May 17, 2009 | 08:38 AM
riko540's Avatar
I lol'd at this thread. If you remove overdrive your removing 4th gear thus making your car slower and killing your gas mileage with it. If you really don't want it just put the car in I instead of D. Here is an article on overdrive: http://en.wikipedia.org/wiki/Overdrive_(mechanics)
Old May 17, 2009 | 08:50 AM
jhop16's Avatar
im not trying to remove it... alot of vehicles with overdrive have a bottun for turning it off for going up hills and ****... my way to and from work consists of 15 miles up and down hills... and i hate the car constantly downshifting
Old May 17, 2009 | 08:55 AM
that is precisely what the lower gears are for on our car and why you can select them.
Old May 17, 2009 | 08:57 AM
jhop16's Avatar
you can select the lower gears?? i'm sorry i'm dumb when it comes to auto, i've had manuel everytime b4 this... there is no 1 - 2 - D - N - R - P theres no numbers on mine... theres like a I and a L or something
Old May 17, 2009 | 09:17 AM
same with mine. there the same thing. here ill explain.
first. know that i belive hunter89 made a good thread somewhere thats really detailed on the auto.
ok
let me begin.
It is impossible to do real damage with ur auto. even in L it will eventually shift to save your car.
L/1- will stay in 1st till 6k i belive. Also turns off TC
I/2-Tranny will shift at slightly higher than normal RPMs 1-2 with increased line pressure but traction control on. Overdrive Can be used in I.
Old May 17, 2009 | 09:19 AM
jhop16's Avatar
so i should use the I when going over hills?? seems like 2nd gear would be a little low for going 55-60 imo but maybe im still not understanding idk
Old May 17, 2009 | 09:22 AM
honestly just mess around while driving. YOu wont do any damage if your stock and your tranny is not tuned or has a shift+ on.
Just dont go directly to L. GO D to I to L
yo can go Directly to drive anytime
its hard to explain. you need to get a feel for the car/tranny and most of all the engines power band which is a bit high in the RPM range
Last edited by originaladrian; May 17, 2009 at 09:22 AM. Reason: Automerged Doublepost
Old May 17, 2009 | 09:26 AM
riko540's Avatar
ok
let me begin.
Thats strange I thought I/2 only went through 1st,2nd,and 3rd gears but not overdrive. If what you say is true than it would if you redlined to save the tranny.
Old May 17, 2009 | 09:29 AM
U may be right.... Actually.... welll
I cant think right now....
uhhh CSSnet.... does I allow overdrive???
I could have sworn i can slam down my gas in I and get overdrive to kick,
it would shift to save your tranny
I know for a FACT thats true.
hehe
Last edited by originaladrian; May 17, 2009 at 09:29 AM. Reason: Automerged Doublepost
Old May 17, 2009 | 10:20 AM
jhop16's Avatar
kay now, last Q , does it hurt the car driving with the I insted of D??
i just went and drove it useing the I option and i love it... but i dont wanna hurt the car... it didnt even rev up that high, just insted of shifting to OD, it stayed at like 3500 - 4000 rpm at like 55-60
Old May 17, 2009 | 10:48 AM
riko540's Avatar
No it shouldn't but you'll see your gas mileage go down the tube lol
Old May 17, 2009 | 10:57 AM
Red07SSNA's Avatar
^^Correct.
"I" is full automatic without OD. Your tranny will shift up 1-2-3 at slightly higher RPMs than in "D"...and down shift 3-2-1- automatically as you slow. Your gas mileage will go to "Heck" though simply because your engine will be revving higher than is necessary.
Think of it this way: "I" is not "2nd" in the Cobalt.
Old May 17, 2009 | 11:23 AM
jhop16's Avatar
idc bout gas mileage, i just wanted to make sure i'm not going to burn out the tranny or nething, and i like how it downshifts aswell, sounds cool w/ a aftermarket exhaust
Old May 17, 2009 | 04:15 PM
diablo9287's Avatar
i believe it says you can daily drive with it i "I" in the manual actually
Old May 17, 2009 | 04:25 PM
reaper89's Avatar
L=drag racing(start off with) I=spirited driving D=everyday normal driving
Old May 17, 2009 | 06:28 PM
in my experience, using I will keep your RPMs around 3krpms when on the throttle, and above 1.5krpms when off the throttle. It will not go into overdrive. L will not shift from 1st to 2nd until redline, and will downshift to first if the RPMs will be above 4500, and downshift to 2nd (assuming you're going from D/I into L) if the RPMs will be above 5600 after the shifts
Old May 17, 2009 | 06:45 PM
I was waiting for you=)
Old May 17, 2009 | 06:57 PM
here i am! to the rescue! lol
^^ yea, that was kinda gay...but im really bored
Old May 17, 2009 | 07:50 PM
jhop16's Avatar
so its safe to use the I option then?... idk why i'm so paranoid about it , but these cars tend to have the stupidest problems
Old May 17, 2009 | 11:29 PM
its just as safe as L, D, N, R and P....
Old May 18, 2009 | 11:33 AM
olivecj's Avatar
I like using "I" when i wanna drive more agresively. I consider it sport mode while "L" is drag mode. Also i find since i'm modded I mode works even better now.
