People with knowledge on gauges look here
Old Oct 10, 2006 | 11:25 PM
celicacobalt's Avatar
As soon as i figure out exactly what i need to buy i will be getting the triple gauge pillar from autometer and 3 gauges being a full sweep vacuum/boost gauge. a full sweep oil pressure gauge, and a full sweep tranny temp gauge. These all being the cobalt series by autometer. My question is mostly to do with the automatic tranny temp gauge... basically on the autometer website it says there may be a need for extra accesory parts for the the tranny gauge to work with certain cars. So can someone tell me if i would need other parts to make this work and what they would be? thanks alot for the help as i am eager to buy these and get them installed before my turbo project so i can monitor some numbers pre turbo 1st.
Old Oct 11, 2006 | 07:14 AM
denniss's Avatar
You might need an adapter to mount the sending unit, but it should be just e temperature probe. You will need an adapter for the oil pres
sure gauge. Are you installing mechanical or electric gauges?
Dennis
Old Oct 11, 2006 | 03:39 PM
slvrbalt's Avatar
hes going with the electrical gauges as far as i know unless the tranny temp dont come in electric, let me check
Old Oct 11, 2006 | 03:56 PM
slvrbalt's Avatar
http://www.autometer.com/cat_gaugede...gid=2569&sid=4
http://www.autometer.com/cat_gaugede...gid=2571&sid=4
http://www.autometer.com/cat_gaugede...gid=2573&sid=4
looks like you shouldnt need anything other than what comes with the gauge if i read right, but someone back this up as i am not sure.
Old Oct 11, 2006 | 08:48 PM
ok so ill buy them and it should be all good right?
Old Oct 11, 2006 | 11:02 PM
denniss's Avatar
The oil preassure gauge will need a adapter, 12mm x 1.5mm I think. It is avalible from Autometer. I had to make a tee fitting so the stock sending unit could still be used. I think someone installed a oil preassure gauge in one of the oil galleries by removeing a plug, but I am not sure which one.
The 2.4 does not have any vacuum lines, so I slpiced into the line going to the master cylinder. A trip to the hardware store for parts will be needed.
You will have to drill a hole in the trans pan to install the sending unit for the trans temp gauge.
I found installing gauges a little challenging but well worth the effort.
Dennis
Old Oct 12, 2006 | 09:46 AM
ok, i wont be doing the install on these ill be taking them to the performance shop that will be installing my turbo kit, ill bring this up to him to make sure we have all the parts, thanks
Old Oct 12, 2006 | 12:30 PM
Dennis
can you direct me to the exact part i need as far as the adapter 12mm x 1.5mm im not sure what kind of adapter that is. i talked to my performance guy and he said he didint think it would be needed but to have it on hand just in case so i will, he wants $230 to install all 3 gauges so i hope thats a fair price. but as soon as you can help me find that adapter then im ordering the gauges. thanks.
Old Oct 12, 2006 | 07:30 PM
denniss's Avatar
You will need
Electric Temperature or Pressure 1/8" NPT to M12x1.75 Product #2278 from Autometer.
Your sending unit will screw into this. I think you will have to keep your stock sending unit, so you will have to fabricate a tee fitting or install your new sending unit somewhere other than where the stock one is. I think there are 3 oil gallery plugs on the back side of the block under the exhuast manifold. If you are installing a turbo, you will probably have the manifold off anyway so one of these would be a good choice. they are also M12 x 1.75 thread, so you will still need the adapter.
Sorry I said 12x1.5 earlier, I forgot the size. Just checked it in the service manual and it is M12 x 1.75.
Dennis
Old Oct 12, 2006 | 10:58 PM
http://www.autometer.com/cat_accesso...il.aspx?vid=62
thanks, just to make sure, this is it right?
Old Oct 13, 2006 | 06:52 AM
denniss's Avatar
Yup, thats the one.
Dennis
Old Oct 13, 2006 | 10:51 AM
cool thanks, i think im gonna order from turbo tech racing as soon as he gets me a package price quote
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
