A pillar gauge pod
Old Apr 8, 2008 | 11:44 AM
SilvrLT's Avatar
A pillar gauge pod
I want to install a triple gauge pod on my a pillar, but I am leary b/c I dont want to F**** up my side impact air bags. Help????
Old Apr 8, 2008 | 11:48 AM
Drakonen2000's Avatar
you wont mess up your air bags...they arent on the actuall pillar plastic! it looks like a thick wire that runs along the actuall A-Pillar itself...the plastic wont mess it up at all, just might hurt a lil more if it ever does go off
invisible's Avatar
Subscribed+free bump
Old Apr 8, 2008 | 01:21 PM
SilvrLT's Avatar
I know it's not on the plastic, I am more conserned woth getting a face full of gauges if i get into a accident
Old Apr 8, 2008 | 01:22 PM
eh...you win some you lose some! lol...thats the danger with having them there, and honestly with a 2 pod pillar the gauges are far enough away that i doubt they would ever come close...but with a 3 i could see cause for concern! either way, you take the good with the bad...theres no way aroud that...
Old Apr 8, 2008 | 01:24 PM
SilvrLT's Avatar
yeah your right, I think I will go with a 2 pod instead Thanks for your help!!!
Old Apr 8, 2008 | 03:11 PM
dtabbs's Avatar
Take a look at the A-Pillar pod and guages I just installed this last weekend.
https://www.cobaltss.net/forums/electronics-audio-video-49/aem-wideband-interceptor-installed-105237/
I dont have side curtain air bags but even if you do you can see that the air bag would push the pod to your right and forward away from you and to the windsheild. The bag is only in the roof by your head and not the A-Pillar.
Old Apr 8, 2008 | 03:32 PM
nuttzzy's Avatar
i do know the triple piller from ca requires a bit of force to make it work its not an exact fit you can tel its not right
Old Apr 8, 2008 | 03:36 PM
SilvrLT's Avatar
https://www.cobaltss.net/forums/showthread.php?t=105237
Those look great dtabbs!! Thanks for the pics!!, Did the 2 pod pillar install easily???
Old Apr 8, 2008 | 03:39 PM
it takes a little pushing and nudging...and chances are you will have to glue in the little screw cover...but all in all it took me about 10 mins
Old Apr 8, 2008 | 04:22 PM
SilvrLT's Avatar
I went to cobalt addictions website to order and it says they don't sell pods?? wtf??
Old Apr 8, 2008 | 04:40 PM
its under performance / gauges
Old Apr 8, 2008 | 05:30 PM
dtabbs's Avatar
The pillar does actually fit quite nice excepting for a couple things because I am a perfectionist. It is a little longer than the stock one, but I did not try to cut it down because I did not want to ruin the painted finish. The supplied faster could have been a bit more thought out instead of a semi counter sunk hole and a counter sinking wood screw that when you put the little cap on the top you can still see the head of the crew and it looks like it has a sombrero on it. The color matched color, if you go for that option is not quite right, as it should be grey and not tan.
Old Apr 12, 2008 | 12:52 PM
Turbo06Sedan's Avatar
If anything, if it does go off..its going to slap your passenger and not you. lol
Old Apr 16, 2008 | 01:31 AM
rmorris003's Avatar
I just installed a SS/SC A pillar into mine and had to cut the big white plastic pieces that stick out so it would fit but it looks like factory. I had my battery disconnected while doing this and nothing is messed up.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Sep 27, 2015 08:53 PM
