Please help!!!!!
Old Apr 25, 2010 | 12:52 AM
deline1985's Avatar
Please help!!!!!
I fucked something up on a really simple maintenance job and i cant figure it out. Please help!!! i removed my air filter for cleaning and decided to clean the throttle body as well. i unbolted the throttle body and disconnected the wire harness and started cleaning it with solution and paper towels. i then went to hook everything back up (install filter, MAF sensor, throttle body and wire harness). i go to start my car and now its idling at 2500-rpm!!! i checked and rechecked everything to make sure everything was hooked up properly and it is. i was told maybe i broke the motor (electronic throttle body) when i was moving the flap while cleaning, or the sensor went bad. ANY IDEAS???????
Old Apr 25, 2010 | 12:54 AM
thesteed46's Avatar
Try disconnecting the battery for at least 10 minutes and put it back on and start it.
northvibe's Avatar
what did you use to clean it. did you take the sensors OFF the throttle body or leave them on and get "solution" on/in them?
did you try disconnecting your battery.
Old Apr 25, 2010 | 01:08 AM
deline1985's Avatar
already disconnected the battery and waited. that cleared the service engine light. and i made sure not to get any solution on the sensors or the harness plug. i used brake cleaner. used it before on other cars and no problem.
Old Apr 25, 2010 | 01:13 AM
x-ception's Avatar
Are you positive that the tb is on all the way? Like... no vacuum leaks. That would be my guess.
Old Apr 25, 2010 | 01:15 AM
thesteed46's Avatar
Yeah a vacuum leak would make sense.
Old Apr 25, 2010 | 01:32 AM
deline1985's Avatar
positive. pretty sure there is no vacuum leaks but its kind of hard to hear with the motor idling that high. thought it was the gasket but then i realized the gasket is recessed slightly and part of the tube underneath the TB.
il try to take and post pics sunday night. i dont think i missed anything but who knows.
Last edited by deline1985; Apr 25, 2010 at 01:32 AM. Reason: Automerged Doublepost
Old Apr 25, 2010 | 01:35 AM
Mnatvyc1223's Avatar
why are you using brake cleaner on electronics?
just go back over everything you did step by step and make sure everything is hooked up and installed the way it should be. simplest solution.
Old Apr 25, 2010 | 01:44 AM
deline1985's Avatar
i wasnt using brake cleaner on "electronics". the electronics on the TB are covered and sealed minus the sensor plug. but like i said i was very careful to not get any on the plug.
Old Apr 25, 2010 | 01:47 AM
ecot3c inside's Avatar
how much did you spray?? it may idle high because you doused the **** out of with brake cleaner.
Old Apr 25, 2010 | 05:19 AM
outtamymind's Avatar
depends on what brake cleaner he used. some are varsol based and others like i've used for years are alcohol based which i've used to clean maf's and a few other electronics.
Old Apr 25, 2010 | 06:20 AM
_UnLiMiTeD_'s Avatar
ive heard a handfull of people having this issue when cleaning their throttle bodys.
Old Apr 25, 2010 | 08:42 AM
deline1985's Avatar
not sure what the base of the cleaner is. might of been alcohol only because it kept drying up on me so i had to keep re-spraying.
Old Apr 25, 2010 | 08:47 AM
EatonTVS07's Avatar
Do you know anyone else with a cobalt near you that you can switch out throttle bodys with, just to test?
Old Apr 25, 2010 | 08:50 AM
deline1985's Avatar
unfortunately, no
Old Apr 25, 2010 | 02:13 PM
that would be alcohol based
and ya the throttle body's have been known to be quick picky when cleaning them
Old May 27, 2010 | 09:47 PM
fizz07SS's Avatar
the ECU has to get reprogramed, through GM Tech II or tuning software.
once the ECU is reset the Idle will lower to about 800-900 RPM, and u'll be good to go
hope this helps u out!
Old May 27, 2010 | 10:27 PM
mmcgee123's Avatar
Unhook battery touch neg and pos cables togeher for 20min
Old May 27, 2010 | 10:33 PM
donkeyballs's Avatar
Old May 27, 2010 | 10:59 PM
ctg5040's Avatar
I'm pretty sure he's serious, it drains all the juice from the system.
Old May 27, 2010 | 11:11 PM
1997cavz24's Avatar
To check for vacuum leaks its as simple as spraying brake clean on the areas you may think have a leaks if there is a leak your idle will change noticeably. as for getting a reflash that is near imposable you f'd up you PCM by cleaning your TB. Check all conectors you removed to make sure you didnt bend pins. and yes disconnecting your battery and touching the cable leads together is exactly what you should to do to clear the codes quickly. Any retard knows that if you jump the posts on the battery thats a bad thing. im sure thats not what he meant. Chances are you did not plug a sensor in all the way or bent a pin. Easy fix just take your time.
Old May 27, 2010 | 11:24 PM
ctg5040's Avatar
He wasn't saying jump the battery terminals together. Take the battery out of the picture for a second. Just connecting the positive and negative wires coming from the car itsself will close the circuit and drain any other sources of power (capacitors that are also in the system).
Old May 27, 2010 | 11:26 PM
1997cavz24's Avatar
Exactly what i was trying to say
Old May 28, 2010 | 12:14 AM
mmcgee123's Avatar
Completly serious it drains all keep alive memory also helps if u turn on the headlight at the same time not like this is my job or anything
Old May 28, 2010 | 03:29 PM
fizz07SS's Avatar
WHATTTTT!! who told you that, lol ...hope that was a joke... But THat questions was answered on the thread above ur, with the same probleam.
