Point at which power kicks in
Old May 27, 2008 | 07:19 PM
bigworm's Avatar
your tuner used the magical '0'. congrats.
Altiery54's Avatar
Originally Posted by Psykostevo
I can tune 07's, and have. The SS/SCs do not have the timing dip or torque management that the 2.4Ls have.
Not even!
can u remove tq. management on 07's?
Old May 27, 2008 | 07:20 PM
Psykostevo's Avatar
Originally Posted by JohnnySasakiMGS
Thats the Eco-tak. It kicks in at 4k.
Nope, Ecotec is always working, doesn't kick in at any particular RPM.
bigworm's Avatar
aw come on.. i wanna see a fight between a mustang guy and the supercharged hhr guy...
Old May 27, 2008 | 07:22 PM
Psykostevo's Avatar
The SS/SCs don't really have TQ Mgt as aggressive as the 2.4s but yes it can be tuned out. I have tuned the 05-07s and they all pretty much tune the same. The 05's do have a couple different tables.
Just don't divide by it!
I I don't believe you input 0 I think its like 6242
Last edited by Psykostevo; May 27, 2008 at 07:28 PM. Reason: Automerged Doublepost
bigworm's Avatar
you can raise the limits to a thoertical "highest" value per gear, and per throttle position.
Old May 27, 2008 | 07:23 PM
Altiery54's Avatar
interesting i am getting tuned by wickedss. thanks 4 the info though
Old May 27, 2008 | 07:27 PM
Psykostevo's Avatar
Originally Posted by BennyHHR
Bullshit...
The lack of reaction is due to GM's tune for both EPA gas mileage and EPA emissions. There is a big delay as to when PE kicks in and has NOTHING to do with "torque limit".
Psykostevo: Direct question... Having had the opportunity to scan one of your LE5 "toons", why does the Commanded AFR hit in the 9's on a hard pull??
The simple answer to that 14 month old problem is that the flow tables at that time were being calculated off of provided information that the injectors at hnd were 34# and that was not the case. I had based the fuel tables off of the difference of what I was told was 24# and 34#, and errors resulted in the fueling as a result. As for the commanded AFR, it was never set below 12.1 so I don't know what you saw when you say 9's.
And the reaction does have a part to do with a torque table and timing table, and if the stock delay is set to ~8,000rpms then why does it kick in at 4,000rpms? And why does the timing table have a magical dip right at the ~3,750-4,250 rpm range? And why are there tables limiting torque at below 3 or 4k rpms?
Take your disrespect and shove it up your ass. If you ever made a mistake you'd never let yourself live it down. You must do everything right the first time. I took a step forward to help the 2.4L owners at a time when noone else was working with them and I presented them with some hope, some solutions, and a place to start. You can sit back and criticize from behind your shadows, but I am out there helping these people every day and trying to build this community into something worth logging into everyday.
Go be a comment sniper in another forum where people play by those shallow rules.
*edit* And also some people passed those files around without asking my permission or asking what they were to be used with so they put tunes on their cars for the wrong injectors, and for cars with and without CATs. That would be their fault if that were the case. Any other problems caused to people that I intended them to be used on were my fault, and not very frequent. There were a few people out there who asked for the tunes, yet a lot more people out there who are using them thanks to people like DOC and other tuners who couldn't wait to get their hands on them. As most people know, I tune each car independently and treat each person different. I only send out generic files or recycles when people ask for some info, or don't provide details.
Old May 27, 2008 | 07:28 PM
bigworm's Avatar
actually your starter should kick your ecotec into working around 800rpm... then that little peddle thing on right side of the floor makes it go faster.
Old May 27, 2008 | 07:29 PM
Psykostevo's Avatar
*wish granted*
  #36
chevyLSchik's Avatar
*grabs popcorn and soda*
Old May 27, 2008 | 07:30 PM
  #37
Psykostevo's Avatar
Well obviously you have to start the car first :-P
Old May 27, 2008 | 07:32 PM
  #38
Brandon97Z's Avatar
Brandon is correct. you lower the value, you dont "delete" it.
thank you i thought i was right.
My ecotec only starts working when i turn the key maybe i should take it to the dealer.
Old May 27, 2008 | 07:33 PM
  #39
hey i quoted "delete" does that count?
Old May 27, 2008 | 07:34 PM
  #40
Brandon97Z's Avatar
nope
Old May 27, 2008 | 07:35 PM
  #41
and this is why my car is appearance oriented! i dont know much about performance...and yet im a beta tester :S
Old May 27, 2008 | 07:47 PM
  #42
bigworm's Avatar
beta testing what?
you beta test shirts?
Old May 27, 2008 | 07:49 PM
  #43
Brandon97Z's Avatar
I see *****
  #44
ecotecon18s's Avatar
and that is why you are one of the more respected and sought after people on this site.
Kudos to you sir for being part of the solution.
Old May 27, 2008 | 07:50 PM
  #45
steddy2112's Avatar
Psykotune
FTW
Old May 27, 2008 | 07:51 PM
  #46
bigworm's Avatar
Originally Posted by Brandon97Z
I see *****
i need an age on those things before i comment any further...
aww.. who am i fooling? I SEE BOOBIES TOO!
Old May 27, 2008 | 07:52 PM
  #47
steddy2112's Avatar
FTW
Old May 27, 2008 | 08:30 PM
  #48
WhiteSSBalt's Avatar
Not a Sebring
Originally Posted by originaladrian
thts why u downshift, get them RPMs up
Old May 27, 2008 | 08:48 PM
  #49
Psykostevo's Avatar
beta testing what?
face pics!
Originally Posted by steddy2112
Psykotune
FTW
I still need to get you your stock tune. That laptop is hopeless.
Aww, I'm going to cry.....
Last edited by Psykostevo; May 27, 2008 at 08:48 PM. Reason: Automerged Doublepost
Old May 27, 2008 | 08:54 PM
  #50
wow im glad you didnt save the other one
and dont worry, im 20....
Last edited by chevyLSchik; May 27, 2008 at 08:54 PM. Reason: Automerged Doublepost
