Question about warrenty and HPT
Old Jan 29, 2007 | 11:59 AM
rcmpayne's Avatar
If I took a backup from HPT then buy a second ecu from a junk car and use that for my mod.
If I put the original back in the car can gm tell I have done anything?
I have a friend that wants to do this with a second ECU but does not to loose warranty.
Old Jan 29, 2007 | 01:16 PM
bc3tech's Avatar
sounds like it should work. i'm not sure if the ECM has the VIN "hard-coded" into it tho.
Old Jan 29, 2007 | 01:39 PM
rnjmur's Avatar
You can use the other ECU - however i'm not sure if it will record differences in mileage or not if you put the old ECU back in... I'm sure somebody on here knows more about how the ECU works and can shed some light on your question
Old Jan 29, 2007 | 01:57 PM
NGalaxyTimmyo's Avatar
from what I understand, you can do that, however, you won't be able to just switch the ecu. I believe you have to take the car up to a dealership and have the car "learn" the new ecu.
However, I think you can get past this with HPT, by doing a write entire, which will put your vin number on the ecu.
I'm sure you'll get a definite answer by tonight.
Old Jan 29, 2007 | 03:04 PM
g5mike's Avatar
the tech would really have to get into your compuet to find out,that being said,for everyday warrenty work they will not be able to tell you have HPT
Old Jan 29, 2007 | 03:13 PM
NJHK's Avatar
Why don't you just save the stock flash and restore it when you need to? I could have sworn that was an option...
Old Jan 29, 2007 | 03:17 PM
g5mike's Avatar
you are 100% correct my buttsakz friend
Old Jan 29, 2007 | 03:26 PM
rcmpayne's Avatar
ok cool so i fthe car breaks or some thing like that i can restore the backup and it;s back to stock?
R33P3R007's Avatar
360 L337 User
yeah.. but if you tune for your mods.. then flash the stock tune to take it in.. your car will run like ****. and could be very dangerous depending on the mods you have
Old Jan 29, 2007 | 03:30 PM
rcmpayne's Avatar
ok so people with a new car and a warrenty. What do they do? do they just say fu@& the warrenty and go for it. has anyone have to bring there car into the dealer for warrenty work with a HPT done??
Old Jan 29, 2007 | 04:03 PM
NJHK's Avatar
Honestly, if you're that worried about your warranty...don't modify your car and get a used vehicle as a project car.
It's like if you're afraid of fires, don't become a fireman.
Old Jan 29, 2007 | 04:31 PM
LandonElf's Avatar
Well said my friend, well said.
Now to the OP,
If your a warranty-***** like myself, then consider the following mods because they will be completely warranty-safe.
1) GM Stage 2
2) GM catback exhaust (4 options, all rock)
3) GM honed exhaust manifold
4) Intake (or air box mod)
5) Ingalls Torque dampener (takes 5 mins to remove but you shouldn't have to)
6) Hurst short throw shifter (yep its a gm part now)
These next mods are not specifically warranty-safe, but you should not have any problem unless your dealership are complete douchebags.
1) GM Dual pass intercooler mod
2) GM Stage 3 pulley
3) GM competitive driving knuckles
Hope this helps! If its any consolation, i have been in the shop for warranty work a gazillioin times and all my mods are completely safe.
Old Jan 29, 2007 | 04:37 PM
rcmpayne's Avatar
thz it's not for me. My friend has a lease car and was wondering what to do
Old Jan 29, 2007 | 04:44 PM
NJHK's Avatar
Umm..is he planning on buying the car after the lease?
If not, it's pretty pointless and can actually be negative when it comes to modifying the car.
Now to the OP,
1) GM Stage 2
Thank You
brandon04
Oct 21, 2015 07:04 AM
patooyee
Oct 15, 2015 05:11 PM
Iceberg
Sep 29, 2015 12:33 PM
Extremespeed
Sep 29, 2015 04:34 AM
Iceberg
Sep 28, 2015 01:31 PM
