question on rotors!!
Old May 15, 2010 | 02:12 PM
cobaltss76's Avatar
do 2008 ss/tc rotors fit a 2007 ss 2.4 ..i figure they would same bolt pattern..just make sure with the calipers..
Old May 15, 2010 | 02:15 PM
08G5GT2.4L's Avatar
Nope. Bolt pattern is the same yes, but the rest of the rotor is different.
Old May 19, 2010 | 04:41 AM
DFZ24's Avatar
sorry to get out of topic, but i see that you have bi-xenon too,
does your high beam works? i mean can you switch from low to high and do flash with high???
reason why i because mine doesn't only low beam is lighting up. cant change or use high beams.
Old May 19, 2010 | 04:45 AM
Dr.Balt407's Avatar
Thread jack! did your turbo kit come in yet??
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
DANRICKARD
Oct 1, 2015 12:08 AM
Sep 27, 2015 08:53 PM
grampss
Sep 27, 2015 08:51 PM
