remote start clutch help
Old Mar 7, 2009 | 04:43 PM
Fishers24's Avatar
im installing a compustar pro alarm with rmote start in my ss and am using the blade al bypass and everything works except its not seeing my clutch i know i have the right wire but can anyone help with y alli get out of it is a ground no matter if it is compressed or not and if it a positive or neg trigger... thanks
Old Mar 12, 2009 | 12:39 PM
kevinj4891's Avatar
there was a reason why they didn't come with a remote start out of the factory. i would not recommend putting it an any Manual drive car. your supposed to leave it in gear when you park. if you some how jerry rig it to remote start, your car will shudder and stall every-time. if you leave your car in neutral all the time, not a safe bet, especially on a hill.
thats probably why no one has responded... if you do get it working, let us know how it goes.
Old Mar 12, 2009 | 06:36 PM
DarkSergeant's Avatar
Not to mention, the Cobalts (or at least the two we've owned) don't have the world's best Hand Brake. Another reason to leave it in gear when you're parked..
Old Apr 8, 2009 | 03:18 PM
Fishers24's Avatar
yo guys i figured out the remote start system all u need is one relay .. with my compustar alarm/rms system the status output wire was neg "might be diff with other systems" ran that to 85. on the relay 12vc to 86 and 87 the yellow wire in the clutch needs to see a positive signal to start so run 30 to that .. the system works great as long as it has a neutral safty switch u will be able to work it fine .. i do reccomend upgrading the tiny 10 amp fuse cause that was the only prob that i had was it blew the fuse.. its on the bcm passanger side..
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
SSLOW06
Oct 1, 2015 07:21 PM
