removing plastic
Old Apr 27, 2006 | 07:48 PM
savior's Avatar
removing plastic
is it safe for me to remove all the plastic in the engine compartment - i am only worried about the wires that are attached to the intake (is it safe to disconnect them)
are there any steps i should know about before removing the plastic
are there any plastic parts i SHOULDNT remove?
Old Apr 27, 2006 | 07:55 PM
mike25's Avatar
yea if i am right do not remove the wire on the intake--i think its your maf sensor wire--,which is critical for your car to run right...the most i would take off concerning engine plastic would be the huge ass piece covering the valve cover
Old Apr 27, 2006 | 07:58 PM
D4u2s0t's Avatar
you shouldn't have to remove any wires to take the plastic off... take out the dipstick, (you don't have to but i broke mine taking the engine cover off) and take off the oil cap or it wont come off... there's only 2 rods holding it in, pull gently in the back left corner and the front right corner and it will snap right off... you may have to pull a little bit the first time... the black one in front of the engine cover to the left bottom side is your airbox, you can't take that off... it's not a cover... i wouldn't take off the fuse cover
Old Apr 27, 2006 | 08:03 PM
RaineMan's Avatar
the only "plastic" part you can take off is the big engine cover that says "Ecotec" on it... just unscrew your oil cap and pull... it sits on two rods and it'll come right off.
the front plastic piece is part of the stock air intake assembly... you'll have to get a aftermarket intake to get rid of that.
Old Apr 27, 2006 | 08:04 PM
savior's Avatar
D4u - where do you live in NJ?
Old Apr 27, 2006 | 08:15 PM
D4u2s0t's Avatar
I live in bloomingdale... what about you?? here is a nice easy breakdown... sorry for the shitty quality i made it quickly in paint
Old Apr 27, 2006 | 09:52 PM
savior's Avatar
ah yeah i already removed the main plastic part, i was just wondering about the intake area, thanks for the diagram....
i live in morristown and commute every day 80 -> 280 heading towards the oranges around 7 am and 5 pm in a black 2.4
dennis69
Oct 20, 2015 07:39 AM
katahdin_lubricants
Sep 20, 2015 07:24 PM
XStylus
Forced Induction
Sep 16, 2015 06:19 AM
chris88z24
Sep 8, 2015 01:55 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
