s/c kit Q
Old Feb 1, 2009 | 01:31 AM
rockstar014's Avatar
s/c kit Q
ok reacently acouple of us 2.4s are going s/c so i figure we help eaother out soo Q num 1 do wee need a lsj fuel rail????
Old Feb 1, 2009 | 01:32 AM
umrdyldo's Avatar
Nope just bigger injectors
Old Feb 1, 2009 | 01:38 AM
stage 2 injectors work?
Old Feb 1, 2009 | 04:09 AM
Zooomer's Avatar
Supporting Vendor
you need EV6 injectors, the LSJ uses GM mini connectors and normally gets upgraded to EV1. For a supercharged kit you can keep the stock 2.4 harness and run either 33# (for low boost) or 39# for higher boost here:
http://www.zzperformance.com/cobalt_...=948&catid=174
http://www.zzperformance.com/cobalt_...=955&catid=174
Old Feb 1, 2009 | 11:21 AM
pjk91's Avatar
i have IDCs in the 80s on a stock pulley. 42s second-hand are plenty...if you don't want to dick around with clips then get the 39s. plug and play.
Old Feb 1, 2009 | 12:11 PM
well ott is installing it soo i wouldnt need to mess with it but they said it would be best just to run 42s
dennis69
Oct 20, 2015 04:49 PM
thewafflesareburnt
Sep 30, 2015 02:29 AM
Sep 28, 2015 12:51 PM
metroplex
Sep 27, 2015 07:48 AM
