SAAB Turbo take offs
With all the hubub about off the shelf turbo kits, I am researching the applicability of pulling a Saab turbo kit (manifold, oil lines, hoses, turbo and other bits and pieces) as a complete bolt on kit to our engines. Its all on the ECOTEC platform so why wouldn't this work? Itd be way more cost effective. Of course you'd want to pull the Saab Vector or Linear system initially and may be upgrade the turbo later. I beleive they are all Garrett bolt patterns.
As another way to easy simplicity, why couldn't we also just use the SC intake manifold have a plate made to put the TB on it and then run the turbo charge pipe right up over the valve cover to the SC manifold? Short tubing=no lag, SC intake manifold and heat exchanger would fit no problem and then just use an SC pump for the HE system?
Big Dan (Djt81185) and twin Loop Dan (Papazz) I have been batting around these ideas on a custom kit, but just like the Nissan's (SR20) and Subies (EJ25) I've owned lent themselves to using other platform turbos and manifolds from other Nissan and Subie lines to do a factory like turbo kit.
Here are some shots of the business end of the Saab Linear engine showing the turbo and piping WITH HEAT SHIELDING. http://cgi.ebay.com/ebaymotors/SAAB-...QQcmdZViewItem
HP Tuners would solve tunig issues as would upgraded injectors.
Does anyone have a contact for a GM engineer familiar with the ECOTEC platforms?
More info from Adam at ECOTEC forums..http://www.ecotecforum.com/forums/showthread.php?p=9006
But specifically the use of the SC intake manifold may make this rather efficient and usig factory parts much easier to install (less piping). Like here on a Solstice http://www.solsticeforum.com/forum/s...ad.php?t=19082
When I bought my 2.4 SS coupe, at my Chevy dealer, one of the salesmen's cousin's bought a 2.4 SS coupe and dropped a Saab turbo in it & he says it's beating Stage 2 SS/SC's, & SRT-4's.
PLEASE GO GET HIS NAME AND EMAIL? I'll pay you for your gas..
I think he might just be bullshiting you, I dont think anyone can tune the 2.2 and 2.4s yet. I could be wrong, but thats just what ive heard......
HP Tuners supports the 2.4.
Originally Posted by PpAzZ1101
Yes! Get more info on this. We've been talking about this for months.
Dano, this is what I and another guy did with our Foresters. We took te entire STI take off, turbo, pluming, vacuum lines and even ECu and BOV and put them on our Foresters. Voila= 55 WHP for $550.!
I am sure once we get solid answers on this, the SAAB systems will bolt on and we can just do the SC manifold with HP tuners!!! Alot cheaper than a custom kit.
Heck yeah. I've already got the manifold sitting there... I have to get Jeff to make me an adapter plate for the TB when he's not busy.
Where do you plan on putting the BOV, if we use the SC intake manifold and short charge pipe...it'll have to go somewhere near the MAF which is also in the charge pipe
Haha... we've been debating this for a while. It may not have a BOV. May just be a bypass valve, recirculating. Then the MAF would be mounted in the intake pipe rather than the charge pipe. The bypass valve would vent from the charge pipe back into the intake pipe after the MAF and right before the turbo.
Well that's kinda what I was hinting at. When I said BOV I actually meant BPV since its a MAF config. But my Subie was the same way. I think we could use the existing CAI hacked up to keep the MAF there in the intake side, put the BPV in the charge pipe and then use a soft pipe from the BPV back over to the intake tube post MAF. It should be failry short and easy to rig up. Wanna see my napkin diagram!!
thats the way I was going actually (with the plate system over stock manifold and using the stock saab turbo manifold) I think it should work... I'm also stuck on maf and BOV placement at the moment... but I'm at least 2 months away from finishing my motor so I'm not worrying about it yet
GTP: I gotcha now. Sounds like a plan. And Jeff is the guy from 1st Try Engineering that Wes and I go to for work (he did the twin loops and cat-deletes).
06blackg85ss: So you didn't get rid of your Cobalt????
I'd be interested to see data on why Hahn says they like the BPV in the charge pipe as opposed to the intake pipe?
There's a guy over on the solsticeforum.com by the name of boostedsol that used the IM and aftercooler off the s/c in his 2.4 turbo setup. I'm sure he could help with the maf/bpv placement.
Originally Posted by WSFrazier
Jeff FTMFW. Allen and I are gonna put the MAF in the charged pipe with a BOV. Dan is against it.
Thanks Brandon, I'll track him down.
Originally Posted by djt81185
Damn straight I am and I have my reasons...I dont look forward to tuning one wit the maf in the charge pipe...all that extra work just for noise
I think it would wreak havoc on our type of proposed set up with the BPV valve dumping so near the MAF. It'd be almost impossible to ensure no MAF turbulence with high bosst levels. Here comes full throttle boost stutters and Codes WES...
