studdering/hesitation problem
Old Aug 30, 2008 | 03:08 PM
glen229's Avatar
my car hesitates or studders when under wot at either low or mid rpms? this is after installing my obx header and catless dp
nobody? bump
Red07SSNA's Avatar
Any DTCs or CEL?
Old Aug 30, 2008 | 03:16 PM
glen229's Avatar
no codes at all
is there a possiblilty the header still needs to break in?
Old Aug 30, 2008 | 03:17 PM
Red07SSNA's Avatar
Did you erase DTCs -- even if you don't have any the factory service manual states that you must erase the DTCs when messing with the HO2S sensors to reset the learn values. It says that if you don't when replacing them you can damage them. Taking out a H02s and reinstalling it in something else will have the same effect. Disconnecting the battery does not do it. Try erasing and see what it does.
Old Aug 30, 2008 | 03:20 PM
Jimmys2007CobaltSS/C's Avatar
Manual or auto?..not sure if that makes a difference
Red07SSNA's Avatar
Also....did you do the sparkplug anti-fouler mod on the 2nd H02S? Without the cat your 2nd H02S will give give you a CEL/DTC -- can you tune it out?
Old Aug 30, 2008 | 03:24 PM
glen229's Avatar
thank you for the quick response.... i didnt erase anything.. whats a DTC ... ill disconect the battery again and go from there
i didnt do anything i dont know why i dont have a code lol i wouldnt have had enough room for the non fouler and my 02 sensor
it can be HPT out... when i get that money lol
Old Aug 30, 2008 | 06:10 PM
Red07SSNA's Avatar
DTC is a trouble code that your ECM/PCM can set -- you have to read it with an OBD II reader (Autozone can read them). Normally you see a CEL but your ECM/PCM can have them stored without a CEL. Disconnecting the battery doesn't reset the learn values, only by erasing them with a "erase" feature on a scan tool does it.
Old Aug 30, 2008 | 07:48 PM
glen229's Avatar
yeah no codes i have the scan tool also.. but its weird its a big hesitation idk what its from it jerks you around when it happens
Old Aug 30, 2008 | 08:11 PM
Red07SSNA's Avatar
Doesn't make sense! If it is just the header and DP that you changed, you shouldn't have that problem.
Sounds lame...but are you sure both H20S sensors are securely connected?
The problem only occurs when you go WOT, correct?
Old Aug 30, 2008 | 09:59 PM
glen229's Avatar
it happens when i apply a load at about 2-4k on the tack.. its a good sized shake/hesitation.. then it just revs out all fine.. im going to be going to SMG on tuesday to take fred for a ride to see what he says... i still cant figure out this friggen squeaking/chirping noise that happens when i accelerate also>>> ahh idk
nobody else has any other suggestions!! i cant be the only one with this that happend...
Old Aug 30, 2008 | 10:22 PM
chad463's Avatar
I had the same hesitation under WOT and I changed my plugs and it fixed it
Old Aug 30, 2008 | 11:17 PM
glen229's Avatar
hmmm not a bad idea .... but my car has 4,000 miles on it .. ya know?
thanks for the post
how many miles did your car have?
Old Aug 31, 2008 | 09:22 AM
chad463's Avatar
mine had 43 000km, not sure what that is in miles.
turbochargedss2012
Sep 20, 2023 12:17 PM
yellow dragon
Sep 28, 2015 09:49 PM
Iceberg
Sep 28, 2015 01:31 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
