Supercharging help...
Old Apr 15, 2014 | 09:05 PM
Jacob4ta's Avatar
If you want to have it always hooked up, yes you need a 3rd bung. If just for tuning I'm pretty sure you can just pull one of the o2 sensors and use that. I'm not sure which sensor though.
Old May 6, 2014 | 02:55 AM
cobalt_sport08's Avatar
How should I go about the coolant system? Since ill have an intercooler now. Just use OEM or flush and use a certain brand, 50/50?
Thanks
Old May 6, 2014 | 09:11 AM
Verbatim's Avatar
use dexcool
Old May 7, 2014 | 12:16 PM
Ok so anothere issue my M8 bolts for the lower IM bracket dont fit into the block. becks build said you need to drill the holes bigger. My holes are already too big and I didnt drill them. Amd an m10 doesnt fit. Also what size are the stuck lsj studs so I can make the lower middle holes bigger.
Old May 7, 2014 | 12:26 PM
redcobalt07's Avatar
under no circumstances should you get a shitty trifecta tune, go with HP tuners.
Old May 7, 2014 | 12:30 PM
I need put together forst -___-
Old May 7, 2014 | 12:34 PM
if those bolt holes are messed up you are probably going to need to re-tap them
Old May 7, 2014 | 01:23 PM
Yep called aroynd got the right stuff working on it now
Old May 8, 2014 | 10:37 AM
Why have none of the how-to said anything about re routing AC lines?? What did yall 2.4s do?
Old May 8, 2014 | 10:39 AM
well on a 2.2 I didn't need to reroute the ac lines
Old May 8, 2014 | 10:42 AM
  #36
Lucky.. its like the bottom left side of the TB (big plastic part) hits the line.. can I just bend them down more or woukd that be a bad idea??
Old May 8, 2014 | 10:46 AM
  #37
i mean if it's a little bit of a clearance issue you should be able to bend it to make it work
Old May 9, 2014 | 11:33 AM
  #38
GOT EVERYTHING on BUT when it fires up it jumps to 2k.. and ideas?? bad TB maybe?
THANKS!
Old May 9, 2014 | 04:28 PM
  #39
Jacob4ta's Avatar
Does it hold at 2k rpm? Or just on initial startup? Does it run rough? What are some of its characteristics while its running?
Old May 9, 2014 | 04:35 PM
  #40
No doesn't run rough but now its going up to 3k
Old May 9, 2014 | 04:39 PM
  #41
And does anyone want to please help me on IAT2 I do not understand that diagram and plus I think my wires are different.. I have yellow, black/stripe, pink, light brown maybe tan colored, then lite blue.. Which are the 2 i need
Old May 9, 2014 | 05:06 PM
  #42
Old May 10, 2014 | 11:00 AM
  #43
Jacob4ta's Avatar
If you follow Becks write-up on the swap, it should be pretty straight forward. I don't recall the exact procedure I followed but feel free to msg him. I'll be seeing him today so I can tell him to assist you if he can.
Old May 10, 2014 | 04:57 PM
  #44
what colors do you need to wire a 2.4 MAF for IAT2?
Ok I believe I have figured out what colors I need. Its blue and tan for a 2.4.
Link for 2.4 MAF wire diagram:
https://www.cobaltss.net/gallery/files/6/1/6/1/3/l61_lap_maf.png
Link for how to wire the maf for iat2s:
https://www.cobaltss.net/gallery/files/5/9/8/7/MapWiringDiagram.jpg
And one more question the wires going to the new MAP sensor. Are they coimg from the MAF or the wires going to the computer? Thanks!
Old Jun 3, 2014 | 12:28 PM
  #45
Ok one last thing. The car still isn't running right. When I turn it on it revs up to 2-3k and I have a P0107 code. I was wanting to read my iat2s but at this point i don't really care no matter which way I wire it up car still revs. So maybe its a bad MAP sensor.
What is a replament I can use for my 2.4?
ZZP days there map sensor won't work on 08 and up and if I go to advanced or auto zone they have sensors with 3 pins instead of 4 like I have now..
Suggestions?? Thanks!
Old Jun 4, 2014 | 09:26 PM
  #46
Verbatim's Avatar
you need LSJ map
Old Jun 4, 2014 | 11:45 PM
  #47
I have that now I was looking around on other forums and I finally have the part #. I think mine might be bad.
And I should've listen to everyone about trifecta. Terrible its been 3 weeks since I've heard from them, so I have an HP tunner guy coming over in a few days hopefully.
Old Jun 7, 2014 | 08:32 PM
  #48
Just installed AEM UEGO wideband and the gauge reads 17 ... 14..... Stays around 15 then slowly creeps up all the way red then I have 3 red dashes that don't go away?? Any idea?
Thanks
GaryGibblez
Jan 14, 2020 10:35 AM
RaginChopsuey
Oct 27, 2015 01:27 PM
brandon04
Oct 21, 2015 07:04 AM
z28addiction
Sep 28, 2015 12:03 AM
medic710
Sep 6, 2015 08:53 PM
