throttle body
throttle body
just want to know what all is needed to run the lsj or the ls4 throttle bosy on a le5 looking at getting one of them so info would be nice alot said with the lsj i don't need a retune idk need info before buy thanks
Here is all the info you need:
Cobalt & Ion ---> ZZ Performance
Wire harness is needed otherwise you will have to do a rewire found in this thread:
https://www.cobaltss.net/forums/how-...through-80620/
LS4 is really too big for a stock LE5.
but won't the computer adjust itself to the more airflow alot of people said it would im not sure also lsj's are easier to find than le5's but i don't have alot to spend
It should work. Though with your intake and exhaust you may throw CELs without a tune. I am not sure how much the computer can compensate. If the throttle body fits into your future build plans then get it otherwise save for your build.
